SOURCE: my dell optiflex system started
Test the computer's Hard Drive. There are a lot of reasons you might want to test your hard drive for problems. One of the major reasons to perform a test would be if your hard drive is making strange noises. This can often be a sign of a failing drive, something a test can point out.
If the problem is a software issue (virus or too much software installed on the PC) running a System Recovery should have fixed the problem. Try running a test on the computer's Hard Drive. A failing Hard Drive causes slow performance (slow boot, slow computer performance, programs takes too long to load or will not laod at all). And another indicator that the Hard Drive is failing is clicking noises. If you hear clicking noises, backup your files as soon as you can.
You can use free Hard Drive diagnostic tools what can be downloaded from the internet. One of them is Seagate Seatools.You can download it from here - click this link
SeaTools for Windows can perform several basic tests that can help determine the health of your hard drive. Your available hard drives and tests are easy to see when the program opens and can be ran with just a few clicks of the mouse.
Hope this help. Goodluck!
SOURCE: Dell Latitude E5520 (4GB Ram
There could be numerous causes for this issue, so it may be hard to narrow down the exact problem. It could be your computer is overheating, has to many background processes running, hardware or software issue. Some laptops have battery settings that can effect computer performance. You may have the battery settings set to "power saving" which could cause it to go slow. At the bottom right on the toolbar, you should have a battery icon, if you right click that you can go into the power saving options. See what it is set to. A high performance settings will obviously increase performance but decrease battery life. Also, Windows 7 has some new graphic settings which are resource intensive, like Aero. Try lowering your Windows GUI settings and see if this helps. You can do this by right clicking on the desktop and going to Personalize. Set it to a Classic Theme and see if you see an improvement.
I wrote a couple of tech article you can read and it may help fix your issue.
Computer Freezes, bad performance article
Computer Processor maxed, poor performance
Tips to speed and clean up your computer
It could be you just need to clean up the computer. There is a good computer clean up/optimization tool called TuneUp 10. You can get a free trial of it by clicking here.
Comment back if you have any questions.
Regards,
G33k
SOURCE: My Dell latitude e5510 freezes
Mine does this too, had Dell replace the motherboard and have reinstalled windows and it is still doing it. Has anyone found what the issue is?
SOURCE: Hello All, My dell latitude e5510
If you have windows XP as Operating System then this freezing problem on plugging external hard drive or freezing while watching a movie extra will persist. Go for windows 7 as operating system in this machine and you will get rid of all these issues... there is some compatibility issues with WinXP it seems... mine is working perfectly fine since i changed the OS to Windows 7. All the best ..
- shashi.
The beeps are post during post the very first work is done by the ram, all the memory in the ram is first transferred to the hard disk, and remains
1 short beep : Normal POST - system is ok
2 short beeps : POST Error - error code shown on screen
No beep : Power supply or system board problem
Continuous beep: Power supply, system board, or keyboard problem
Repeating short beeps: Power supply or system board problem
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
Hope this helps
