Question about Sharp AR-5316 Advanced Digital Imager Copier
Why i get H4 error on 5516 - Sharp AR-5316 Advanced Digital Imager Copier
Gift Ntwana
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Heat roller abnormally low
temperature
When the temperature does not
reach 155°C within 55 sec after
turning on the power, or when it
falls under 145°C during printing,
or when it falls under 100°C
during pre-heating
Posted on Apr 21, 2016
5 Related Answers
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: Ar 5516 display H4 error
H means heat, you need a new fuser.
Posted on Mar 28, 2010
Anthony Karuku
  • 268 Answers
This means that the fusing unit has a problem. Turn off the copier. Open the small side cover on the right of the fuser unit. You will see the wire connectors leading from the unit and carefully remove them.Open the three screws holding the unit and remove it, check the heater lamp continuity if out replace the lamp. Clean the thermistor and return the unit by reversing the removing process. Now try the code and it will work.
Posted on Mar 30, 2010
Xzx Cxc
  • 4 Answers
SOURCE: Problem for Sharp AR-5320 Black
for AR 5320 just check 1- main corona 2- leveling the developer unit 3- clean cleaning plate,
for H4 just rest the machine as mentioned above, if not plz check fuzing unit -- thermostat
Posted on Aug 22, 2010
Anonymous
SOURCE: sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Posted on Aug 25, 2010
Anonymous
  • 28 Answers
SOURCE: i have photocopy sharp ar-5516 and when i switch
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
press 14 and start key twice.
copier should restart normaly.
If not, then you have problems with the fuser, contact me to tell you what you have to do next.
Regards,
Adi
Posted on Nov 05, 2010
Testimonial: "thanks a lot it was very helpful"
My photocopier sharp AR 5516 is showing H4, what is the solution?
There's an earlier response to this question on fixya in Dec 4, 2012. Search "sharp ar5516 error code h4". It's the third hit down.
Jul 09, 2015 | Sharp Office Equipment & Supplies
My Printer is displaying an H4 error
The error code H4 means that you have a problem with the fixing unit. It could one of the item's > The thirmistor or thermal fuse or the fixing heater lamp
Oct 05, 2012 | Sharp Office Equipment & Supplies
The printer Ar-5516 is showing H4 error
this error means:
heat roller abnormally low temperature.
for check:
1- check the heater lamp
2- check the thermistor
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Jul 04, 2012 | Sharp AR-5316 Advanced Digital Imager...
Ma photocopieur shar 5516 marque un message d'erreur H4
H4 error indicates the fuser is faulty and should be replaced.
Jun 19, 2011 | Sharp AR-5316 Advanced Digital Imager...
Solution TO sharp photocopier ar-5516 4 H error
Press the following buttons fast: #, interrupt, C, interrupt, C, 14, Start button.
Oct 06, 2010 | Sharp Office Equipment & Supplies
Problem for Sharp AR-5320 Black and White Copier Ar 5516 display H4 error?
Aug 22, 2010 | Sharp AR-5320 Black and White Copier
Sharp ar 5516 printers error h5. h4
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Mar 28, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
