Sony DCR-HC26 Mini DV Digital Camcorder Logo
Question about Sony DCR-HC26 Mini DV Digital Camcorder
How to delete contents of sony dcr hc 26 handycam?
lafreedom
    Problem Solver:
  • 43 Answers
There is no erase or delete, per-say...you have to re-record over any recordings on the tape in a silent room with the lens cap on.
Posted on May 29, 2014
5 Related Answers
Fixe_You
Jalal Sordo
  • 1800 Answers
SOURCE: SONY HANDYCAM DCR-DVD105 ERROR MSG C:13:02
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Posted on Jun 28, 2009
Anonymous
  • 88 Answers
SOURCE: Driver of Sony Handycam DCR-TRV285e
you can download the drivers here http://support.sony-europe.com/dime/camcorders/d8/d8.aspx?site=odw_en_GB&m=DCR-TRV285E
Posted on Aug 20, 2009
Mitesh Kr Anand
  • 497 Answers
SOURCE: Installing software for my Sony Handycam DCR-HC96
Option 1:
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Or you can purchase the software disk from this link:
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=partSearch&searchText=266675501
NOTE: Since the original supplied software is not available for free download now.
Good Luck!!!!!!!!!!!!
Posted on Oct 01, 2009
Anonymous
  • 30 Answers
SOURCE: accidentally deleted video on camcorder...how do i
When files are deleted they still remain on camcorder hard drive and can be recovered, unless they have been overwritten by fresh data.
The only thing to do so run a data recovery program to see what can be recovered. The only program I have tested is asoftech data recovery software and it had done the job well. download the data recovery from http://www.asoftech.com/adr/
Select the drive where your files were deleted and then do a deep scan. It will find your deleted files.
Posted on Oct 14, 2012
Anonymous
  • 30 Answers
SOURCE: How can we recover accidentally
38helpful
5answers
I've a Sony DCR-HC 30E/HC 40E Handycam. I've lost the CD-Rom software. I've a Windows XP PC. Kindly let me know ASAP how can I installed the CD-ROM to transfer Videos from Handycam to my PC via the...
With the firewire cable, you can use Windows Movie Maker to download videos from practically any digital camera with firewire connection (Sony called i.Link).
Sony video camera DCR-HC-26. Bought Camcorder
I would take it back to Radio Shack and demand your money back. I would do some research on sony's website and find the right cleaner for you camera.
2helpful
Board dcr-hc 32
dear sir
good evening,
i have bought the sony handycam DCR-HC32. cam is working in order. but there is some problems. that the red colour on LCD is off. what is the reson.
pl explain the fault & repair reson.
thanks
[email protected]
I link in DCR-HC 54 models
try to go here and download the driver or just look for your model and download on that link. install it to your pc.
http://www.sony-asia.com/support/download/1656/product/dcr-hc39e?site=hp_en_AP_i
try also here
http://download.css.ap.sony.com/consumer/IM/2584907131.pdf?p=1
CHARCOIS
13helpful
Sony DCR HC 40 E driver
I had purchased the laptop with Window Vista Home Premium OS. I am unable to connect my Mini DV Sony DCR HC 40 E through firewire. the laptop doesn't recognise mini DV. Please suggest proper driver & solution
2answers
Software
This software is avaliable on charge basis at Sony stores.
20helpful
3answers
USB driver for sony handycam
i need USB driver for my sony handycam DCR-HC51E
Top Sony Video Cameras Experts
Marvin
Marvin
Jaime Hernandez
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
