SOURCE: vtech cordless phone appears to be mute
does anyone out there have a solution for peggy's problem? I have the same problem------Bob
SOURCE: Not Registered Problem
This worked for the 7100, hopefully it works for other models:
When the handset says "not registered", it should still have a "menu" option. Select that, then the only choice is "register", select Ok. Now it says "searching for base", press and *hold down* the "locate handset" button on the base until the handset beeps and wakes up. Docs say this could take up to 30 seconds (it was about 17 for mine).
SOURCE: hi, how do you turn the ringer on of vtech 5.8 GHZ
http://www.retrevo.com/d/ds/progress?doc=415c14b0b538f65e013116610ddd5a8a
Click on the above for your manual and go to p7.
Hope it helps!
SOURCE: how do you delete missed call message from vtech
Open the caller ID screen and scroll through the recent calls. Hope this helps =]
SOURCE: How do I delete missed
If you want to remove "missed calls" on phone, press and hold "OFF" button on handset. This should remove "missed calls" message.
Regards
