Question about Samsung AW0893L Air Conditioner
Well first off is the compressor running? When you turn on the unit the fan will start. Turn the unit on to fan only. Then turn it into the cooling mode do you hear something else start? That would be the compressor. Remove the front panel so you can see the cooling coil (evaporator ) if it is freezing and has frost on just part of the coil top or bottom you have lost Freon or a system restriction.. One of the major problems with air cons is a very dirty or plugged condenser coil, which is the outside coil. If you have cotton wood trees in your area this is probably the problem.
Hope this helps Lynn
Posted on May 29, 2014
