Ive upgraded pc's from vista to windows 8.1 64 bit. It seems that the software invoices and estimates pro v2 is not working. i've called tech support twice, they said i installed incorrectly. Uninstalled and reinstalled twice. Ordered the "update" version, its the same I currently have now. It was not an upgrade. However, tech support tells me that is the newest version and will work. Can you help?
Unfortunately windows installs are a total jailbreak sometimes. the problem might be with the windows install, not the apps. Try repairing winndows. Put the windows disk in the drive and boot the system. There should be a repair option. Also, try the system file checker, sfc.exe:
Start a cmd prompt as administrator and type in:
sfc /scannow<enter>
You'll need the install disk in the drive for this. If that doesn't work, you'll probably need to reinstall windows from scratch. That sucks, but windows sucks, so you're stuck. After the install, run windows update until it says you're up to date and then install the problematic software first.
