Question about Husqvarna Lily 540 and 550
Why won't Viking Lily do a wide zig zag ? - Husqvarna Lily 540 and 550
loosenut
  • 82 Answers
The Viking Lily is designed to do a 6mm wide or smaller zigzag
Posted on Feb 09, 2015
3 Related Answers
Pamsquilt
  • 201 Answers
SOURCE: Viking Designer 1 won't stitch correctly
Check that twin stitch width safety is not turned on in the SET menu (use More button at bottom of first screen to access third screen).
Posted on Jul 01, 2008
Korede Atunrase
  • 1456 Answers
SOURCE: I have a Viking 6370 sewing machine. I can not
Hello
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
Posted on Jul 12, 2011
Testimonial: "That was the problem exactly. I am going to order a new cam gear and replace it. Thanks"
SOURCE: Viking # 1 only sews straight stitch but won't zig-zag
it could also be a worn part, only a sewing machine repair shop can say for sure
Posted on Feb 25, 2012
What do I set my machine for to make very close zig zag stitch. Husqvarna Viking platinum 755.
With most machines after you select the Zig Zag setting you then select the normal stitch knob that can be adjusted for long or short stitch lengths and that should also give you adjustment on your Zig Zag stitch length .
Nov 03, 2017 | Husqvarna Sewing Machines
Elna machine puckers silk on zig zag stitching, Elna 2007
Yes, because a zig zag stitch is creating a wide stitch and the tension on the thread is going to pull the fabric within the seam together, you can't seam thin fabric with a wide zig zag. It will "tunnel together". If you are using this stitch to neaten a raw edge, then try using the serpentine or three step zig zag where the needle pierces the fabric 3 times in each leg of the zig zag, this will give better results.
Jul 07, 2015 | Elna Sewing Machines
How to set machine for zig-zag?
What is the model of your machine?
Check user manual. Manuals are available to view, download, or print from husqvarna viking website -
http://www.manuals.husqvarnaviking.com
Jun 18, 2014 | Husqvarna Sewing Machines
Viking lily 545
You can bend the arm on the walking foot a tiny bit to the left, then turn the machine by hand to see if it stays on, bend a tiny bit more and repeat.
May 13, 2014 | Sewing Machines
Zig zag does not work on Viking 1973
it would be a good idea to have the machine checked to see if
the cam or gear that works the zig zag is damaged or broken..
Mar 20, 2013 | Sewing Machines
Viking 6440 zig zag
Yep, it's out of time. You'll need to either pay to have it timed or Do it yourself. Personally zig zags are a bit of a pain... I would pay.
Feb 28, 2013 | Sewing Machines
Viking 6360 buttonhole procedure
you start with the broad zig zag stitch bar across the top
then you go down the left side using a smaller zig zag stitch
then you make the the broad zig zag stitch at the bottom
then you make the smaller zig zag stitch on the right side
all the way to the top broad zig zag stitch & your done
the right side zig zag does not go beyond the top broad zig zag
stitch
Aug 01, 2012 | Husqvarna Sewing Machines
Feb 24, 2012 | Husqvarna Viking 1
I need to adjust the needle so when I zig zag it will not hit the plastic. It works perfect on stright stitch.
You might have the zig zag set for z-z left or right-hand. Make sure you are choosing the zig zag centre stitch. Also check you are using the correct foot - it should be the A or B foot with the wide opening.
Apr 06, 2010 | Husqvarna Viking 1
Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
May 23, 2009 | Bernina Virtuosa 150
Sewing Machines Logo
150 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
sewcrazyshan
Level 1 Expert
tsalagi152
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
