Symphonic ST419E TV Logo
Question about Symphonic ST419E TV
How do i find a symphonic tv remote control code?
I need to know the code for this TV in order to program a universal remote. Listed codes do not work.
5 Related Answers
Anonymous
SOURCE: programming help
Try to buy another manual (univesal remote control) because its not easy for you to get the codes if it will not work the write to us again.
Posted on Mar 24, 2008
Anonymous
SOURCE: universal remote code for my t v
i need the code
Posted on Nov 22, 2008
Anonymous
SOURCE: forgotten code
the code is026.
Posted on Mar 21, 2009
SOURCE: No remote, need code for universal remote
Try this method:
Turn on the device you want to program.
Press and hold CODE SEARCH until the indicator light lights then release code search.
Press and release the device button you are programing TV, the indicator light will blink once then remain lit.
Press and release OFF/ON until your device turn off.
you may have to press upto 200 times
When your device turn off press enter button the indicator light will go off,good luck.
Posted on Jun 02, 2009
Anonymous
  • 100 Answers
SOURCE: philips universal remote control programming for a
Try 520, 904 or 906.
Posted on Sep 30, 2009
Im trying to program a Panasonic universal remote to clear tunes tv
Search Results
    Need codes for ct-300 clear tunes universal remote - Fixya
    www.fixya.com/.../t17341079-need_codes_ct_300_clear_tunes_universa...
    Mar 26, 2013 - need codes for ct-300 clear tunes universal remote Need codes - Symphonic ST419E TV ... Universal remote code for a panasonic ct-27g14a.
    I have a clear tunes tv and trying to program my RCA universal
    www.fixya.com/support/t25649135-clear_tunes_tv_trying_program_rca
    Apr 16, 2015 - ... a clear tunes tv and trying to program my RCA universal remote to it ... "I need to program an old Panasonic TV with a RCA universal remote ...
    I need the codes to a clear tunes remote for a rca - Fixya
    www.fixya.com/support/t3026751-need_codes_clear_tunes_remote_rca
    Sep 26, 2009 - I need the codes to a clear tunes remote for a rca tv. ... "I need toprogram an old Panasonic TV with a RCA universal remote model RCR311St ...
    Radio Shack panasonic remote control codes clear tunes tv ...
    www.fixya.com > ... > panasonic remote control codes clear tunes tv
    ...remote. the panasonic codefor my radioshack 3-in-one remote is 0250 I need a codefor a VCR Durabrand (DCV603) for the Sony universal remote control or a ...
    Clear tech tv 4 digit code - TV - Other Consumer Electronics
Rca universal remote code for a symphonic tv
0017,0014,0026. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
2helpful
2answers
Need to know how to program a RCA univerical remote to a symphonic tv. and the code to the symphonic tv
the code is 171
the programming process can be found here:
http://www.eliztech.com/remotes/rca-howto.php
I NEED A REMOTE CONTROLLER FOR MY SYNPHONIC TV
Hello
Just buy one "ATLAS METROCAST -OCAP 5 DEVICE" universal remote control. Symphonic TV is listed with its codes. Codes are:
0180, 0171, 1944
Setup proceedings can be had with its catelogue. OK
Need code for comcast remote for symphonic dvd wf104.
Hello
Universal remote code for Syphonic TV with Comcast remote control are:
10180, 10171, 11904, 11913
1. Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
6. For future reference, write your TV code in a safe place.
OK
What is the code for a symphonic tv and a rca remote. I also need insructions on how to program the remote that works with my tv. I lost the instructions
These are the steps on how to program your RCA Universal Remote Control to your Symphonic TV.
  1. Press and "HOLD" CODE SEARCH.
  2. Press and release the TV button. When the TV button flashes proceed to the next step.
  3. Enter the three digit code. In your case, the code for the Symphonic TV are 064 or 076.
  4. Release CODE SEARCH.
  5. With the TV on, press another button, for example CHANNEL UP. If the TV responds, no further programming is required. If the TV does not respond, repeat steps 1-5 using the other code number.
1helpful
2answers
DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
1helpful
Programming the ramote to tv
i dont know how to program the remote for tv..i got the codes
10helpful
6answers
Trisonic TS-RC488
I HAVE A TRISONIC TS-RC488 AND LOST THE PAPER THAT WAS INSIDE THE REMOTE , THE INSTRUCTIONS CAN ANYONE TELL ME THE CODE FOR A SONY TV AND THE INSTRUCTIONS OF HOW TO SET UP THE UNIVERSAL TRISONIC ,,,, THANKS ,,,,, SINCERELY JOHN
Top Symphonic Televison & Video Experts
Steven Wander
Steven Wander
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
