How to convert a rectangular to polar and polar to rectangular equetion.( a+jb)
Eg; 13.78+j7.81= answer in Angular form that is 15.85 angle 29.54
Posted by Mxolsi Khoza on
Stevan Milanovic
    Sergeant:
  • Office Equip... Expert
  • 267 Answers
See cap image below
how to convert a rectangular to polar and polar to - convert-rectangular-polar-polar-hdex2qyz5wphohw1nwwijcck-4-0.jpg
Posted on Feb 26, 2016
labbitibien
    Problem Solver:
  • 5 Answers
The first thing you have to check is if your TI-83 is in the right mode, what I mean is when you press (MODE) you have to be in the Rect. or Polar depending on what you are doing.
Hope it helps !
Posted on Jun 17, 2014
5 Related Answers
k24674
  • 8091 Answers
SOURCE: i am a casio fx-82MS user. i would like to know
Press [MODE] and select [1:COMP]
Press [SHIFT][MODE] and select [3:Deg]. You can also use rad if the angle you are given is in radians.
To start the conversion
Press [SHIFT][-] (Rec) screen displays Rec(
Key in the radius r , ex: 3 screen displays Rec(3
Press [SHIFT][)] (,) to enter comma separator Rec(3,
Key in the angle in degrees, ex: 57.3; screen displays Rec(3,57.3
Press ) to close parentheses; screen displays Rec(3, 57.3)
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
X and Y are the values of the coordinates.
If angle is in radians, [SHIFT] [MODE][4:Rad] the command
Rec(3, Pi) gives X=-3, Y=0
I just realized that your question pertains to the FX82MS but is listed under the FX115ES (That is quite a difference) So my answer above does not concern you but I will leave it as is should anyone need the answer for the FX115ES.
Look at the enclosed screen capture for the FX82MS
Posted on Nov 16, 2010
Anonymous
SOURCE: polar/rectangular
For a TI-86
Converting rectangular to polar
Press "2ND" and then "MORE" for the MODE screen
Highlight PolarC and press "ENTER"
Quit that screen.
Now ready to go.
A example of converting 5+j6
Enter "(5,6)" in the calculator and press "ENTER"
Should get (7.81024967591*angle*50.1944289077)
Converting polar to rectangular
Highlight RectC and press "ENTER"
Quit that screen.
Now ready to go.
A example of converting 5*angle*35
Enter "(5*angle*35)
Should get (4.09576022145,2.86788218176)
Note
*angle* is the symbol when you press "2ND" then ","
Note 2
To round the an decimal places press "2ND" then "MORE" for the MODE screen and on the line that says float, choose a number on that line for the number of decimal places you would like to have.
More can be found at
http://docs.google.com/gview?a=v&q=cache:nAC57BtC6IIJ:myweb.wit.edu/khabaria/ELEC195_files/ti86cplx.pdf+ti-86+convert+to+polar&hl=en&gl=us
Posted on Jul 07, 2009
k24674
  • 8091 Answers
SOURCE: canverying polar to rectangular
Here are exemples from the manual.
Posted on Sep 25, 2009
k24674
  • 8091 Answers
SOURCE: How to convert polar to rectangular form
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
Hope it helps
Posted on Oct 18, 2009
k24674
  • 8091 Answers
SOURCE: can you show how to convert pola to rectangular o
To avoid errors make sure that the angle unit is THE ONE required by your problem. To verify or to change the angle unit press [SIFT][MODE] and select [3: Deg] for degrees, [4:Rad] for radians, or [5:Grad] for grads.
Convert from rectangular to polar
[SHIFT][+] (Pol) . Screen displays Pol(
You enter the X-coordinate, and the Y coordinate separated by a comma, then you close the parenthesis and press [=].
Exemple: Polar coordinate of the point (1,1)
Pol( 1, 1) gives
r=1.414213562 (square root of 2)
θ=45
Here is how you enter it
Press [SHIFT][MODE][2:LineIO]
[SHIFT][POL] 1 [SHIF] [,] 1 [)] [=]
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
Convert from polar to rectangular coordinates
Rec ( radius, angle) =
Exemple: Recatngular coordinates of (r=3, θ=60°)
[SHIFT][Rec] 3 [SHIFT][,] 60 [ ) ] [=]
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Hope it helps.
Posted on Nov 15, 2009
Testimonial: "thanx that was very helpful"
How do I add or subtract numbers in polar form or rectengular form
If one or both numbers are in polar form, convert it/them to rectangular. Once both numbers are in rectangular form, simply add the two components separately: Add the two x components together, and add the two y components together.
If you're asking how to do this on a particular calculator, please specify the make and model.
Oct 15, 2013 | Office Equipment & Supplies
Polar to rectangular conversion working incorrectly
At first, Rect and Polar are a display-format instructions, not a conversion functions. Polar instruction displays complex value in rectangular form a + bi. The complex value can have any complex form. However, an r*exp(i*theta) causes an eror in Degree angle mode according to the TI avowal. See captured images below
Sep 06, 2012 | Texas Instruments TI-84 Plus Calculator
I need to convert the rectngular form to polar form , so how can i do that ?
In Run screen, Press OPTN, Press F6> repeatedly until you see the ANGL TAB. Press F6> again (once or twice). You will see the TAB Pol( and Rec(
To convert from Rectangular coordinates to Polar press POL(, type in the x and y coordinates then EXE
Example: F1: Pol(1,1) gives (1.314213562, 45)
F2: Rec(square root (2), 45) gives (1,1)
Make sure the angle unit is set to the one you need (degree or radian).
Apr 19, 2012 | Casio Algebra FX 2.0 Calculator
How can i enter a polar form number with angle to convert into a complex numbe(a+bi)
Set the calculator to polar form, then simply enter the radius, press the comma key, then enter the angle (in whatever angular mode you've specified).
Full details are in Chapter 2 of the manual you can download from here.
Oct 25, 2011 | Office Equipment & Supplies
How do I convert between the rectangular and polar form of a number with imaginary values? i.e. I want to take the number a+bi and convert it to polar D<(angle) and vice versa.
Use the >Rec and >Pol commands. They're in the Complex number menu, accessible through 2nd [CPLX] MORE.
[CPLX] is the shifted function of the 9 key.
Dec 10, 2010 | Texas Instruments TI-86 Calculator
How to change polar form to rectangular form by calculator?
Use the Rec function (shift of the - key).
Rec(r,t) converts a polar value of magnitude r and angle t in the current angular mode. The real value is assigned to X and the imaginary value is assigned to Y.
Use the Pol function (shift of the + key) for the reverse.
It's on page E-37 of the manual. If you've misplaced your manual, you can download a new one from http://www.casio.com/support/manuals
May 28, 2010 | Casio FX-115ES Scientific Calculator
How can i enter a polar form number with angle to convert into a rect form
how can i enter a polar form number with angle to convert into a complex numbe(a+bi)
Apr 28, 2010 | Casio Algebra FX 2.0 Calculator
Can you show how to convert pola to rectangular o
Pol( 1, 1) gives
θ=45
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Hope it helps.
Nov 14, 2009 | Casio FX-115ES Scientific Calculator
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
Hope it helps
Oct 18, 2009 | Casio FX-115ES Scientific Calculator
Polar/rectangular
For a TI-86
Quit that screen.
Now ready to go.
Quit that screen.
Now ready to go.
Enter "(5*angle*35)
Note
Note 2
Dec 02, 2008 | Texas Instruments TI-86 Calculator
388 people viewed this question
Marvin
Marvin
