Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Mp 2550 sc 819 - Konica Minolta bizhub C250 All-In-One Laser Printer
Ubaid abid
    Sergeant:
  • 164 Answers
819 Fatal kernel error
Due to a control error, a RAM overflow
occurred during system processing.
• Controller board defective
• Insufficient memory
• Expanded memory defective
878
TPM electronic recognition error
The main machine firmware failed to recognize TPM
because USB flash is not operating or a system module
was updated incorrectly.
• Replace the controller
its is unlikely firmware will fix this problem
you probably have faulty controller
Posted on Apr 20, 2019
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,958 Answers
C250 have error codes C-xxxx make and model????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Mar 12, 2017
Aficio MP 5000B sc 819 How can I fix it? please quickly
you didn't specify what problem it has??? does it print?? does it scan? if it doesnt print then check the toners and or maybe it has a paper stuck??? or maybe its the Fuser. a laserprinter has a toner and a fuzer and they both wear out, but people aren't aware about the fuser so when it dies it wont print even if it has a new toner.
Aug 18, 2017 | Office Equipment & Supplies
My machine ricoh mp c2352sp displays SC 819. I can't enter to maintenance mode and it couldn't accept the firmware. Any help to solve it!
You have a bad print job coming in... You can prove it by disconnecting the ethernet cable from the unit and reboot the copier, (cancel the print job, that most likley was printed from the internet) -Carl
Dec 08, 2015 | Ricoh Office Equipment & Supplies
Ricoh mp 2550 sc 160
Sorry, no question so don't know what you want to know.
Jul 08, 2015 | Ricoh Office Equipment & Supplies
Error code SC 565 Ricoh MP 2550
SC565
*Heat lamp consecutive on error - Broken main fuser connection
*Heat lamp consecutive on error - Check HR thermistors with SP1-106 001 (ctr) and 002 (ends)
*Heat lamp consecutive on error - Heat roller lamp defective
*Heat lamp consecutive on error - Power Supply defective
Mar 11, 2014 | Ricoh Aficio 2022 All-In-One Laser Printer
Service Call SC819
I found that this 'SC 819' occurs if you use the bypass tray for the scanner. I found also that this error can be fixed with an firmware update. See link. http://www.copytechnet.com/forums/showthread.php/32934-Ricoh-Aficio-2035-SC819-Error-Code?p=132762&viewfull=1#post132762
I have no idea how to do that at the moment, and I can't report the success of this way.
Jan 22, 2014 | Ricoh Aficio SP C240SF
Richo error code sc 829
I have Aficio MPC 2550 and it displays Sc 829. Is the a way to reset this code?
Apr 05, 2012 | Ricoh Aficio 1035 Copier
Error SC 551 / Ricoh MP C 2550
Hello!
This code is related to a Fusing temperature error.
You probably need to take a look at the heating roller thermistor.
The best advise i can give you is to call a technician to see it (if you do not have technical knowledge)
If you want to reset the code try this:
Press yellow key
Press in the key pad 107
Press red key at least 5 sec.
Press "copy SP"
On the key pas press 5810 and #.
On the touch panel press "execute"
Exit all the way out.
Turn the machine off and on.
Hope this helps you
Aug 04, 2011 | Ricoh Aficio 1013F Copier
TENHO UMA RICOH 161 E DEU O CODIGO SC 819
Isso é um erro de firmware.
Existe uma actualização que corrige isso. Se tiveres acesso a descarregar os firmwares e se souberes como fazer... O teu problema está resolvido.
Contudo aconselho que ligues com a assistencia tecnica. Contacta com a Ricoh portugal e eles enviam-te um tecnico que saberá fazer isso.
Boa sorte.
Mar 01, 2011 | Ricoh Aficio MP 161 Black and White Copier
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
330 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
