If you fill it manually it works as normal
Probably the valve needs replacing.
Check filters on fill hose and valve.If clear is problem either valve or controller
Will it fill from the hot tap?
If so, you might just need a new cold valve.
It would only be either cold or hot that does not work. Replace the Inlet solenoid under the top panel.
You can use the same aftermarket valves for both (Original FP valves are different, cold is wildly expensive compares to hot). http://www.ebay.com.au/itm/Fisher-Paykel-Cold-24Volt-Compatible-Inlet-Valve-Part-FP420148S-/130833870254?pt=AU_ApplianceAccessoriesParts&hash=item1e764e6dae&_uhb=1
It is
possible that the machine does not start off the cycle because there are errors
due to feedback from the inputs. For the program to start up the main program
controller must initiate the INLET/MOTOR/DRAIN
pump/ valve to open up and allow each function to be driven starting from
the flow of water into the drum as also the drain valve to open to exit the
water at the point of the program cycle. If this does not happen then the
voltage at the valve/motor/pump must be checked or the fault relates to no
voltage from the controller. This means
the controller is a suspect.
If the
water flows though the inlet then the flow pressure should be good, if not the
inlet valve is bad or there is dirt in the filter. Also check the flow at the
inlet of the water line. Once the water comes into the system the WATER LEVEL
SENSOR - normally a pressure switch- must activate at the preset/chosen level
to give the signal to the program controller to switch on the motor. What is
most important for the motor to start functioning is that the door switch must
be ON when the door is shut or this will be an error for starting the motor for
rinse and wash.
Test a
pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this
link to replace the inlet valve:
