Canon MP-11DX Calculator Logo
A
Anonymous Posted on May 28, 2014
The times and divide keys will not work. But all the rest do work.
My dog needs 50mg of milk thistle (capsule) but all I could find was 175mg. How do I dose that?
open the capsule and pour the contents onto a plate
place it in a line and divide the line evenly into 3 portions
each portion will be 58 mg which will be ok as dosage is on dogs weight add the powder to the food save the rest till next dosage time and divide the rest in 1/2 and feed 1 portion ,leaving the last portion for the next dosage time
Where is the constant key on the key board?
Turns out to be the = key. I just double-checked it and it's true.
Do a calculation like 10 divided by 2. Every time you enter a number and then hit the equal key, it will be divided by 2.
Where is the constant factor key on Canon P170 DH
How cani i solve "x divided by 9 and x divided by 9 equals 4
x divided by 9 and 9 divided by 9 equals 4, so x divided by 9 equals half of 4 or 2. 2 times 9 equals 18, so x equals 18.
To check, 18 divided by 9 equals 2. 2 and 2 equals 4.
1helpful
How do i factor numbers on a ti-30xs calculator
This calculator does not have a key that you can use to find the prime factor of an integer.
You can however use the calculator to find the factors
1. If number is even divide it by 2
Keep dividing by 2, while keeping track of how many times you divided by 2.
If you divided 5 times by 2 before getting an odd number, then your first factor is 2^5
2. Now try dividing by 3, keep track of the number of times you divided by 3 before you could not divide by 3 any more. If you divided 0 times by 3, your second factor is 3^0, or 1 and 3 is not a factor.
If you divided 4 times by 3, your second factor is 3^4
3. Divide by 5, until you can't any more. Keep track of the number of times you divided by 5.
4. Divide by all other prime numbers 7, 11, 13, 17, 19, 23, 29, 31, 37, 41, etc. For each prime number, keep track of how many times you divided by it, until you could not any more.
Example: 23100
Division by 2
23100/2=11550 ---------> 1 division by 2
11550/2=5775 ----------> 2 divisions by 2
Note that 5775 is not divisible by 2. No more divisions by 2.
First factor is 2^2
Division by 3:
5775/3=1925 ----------> 1 division by 3
1925/3=641. 66667 Not an integer. No more divisions by 3.
2nd factor is 3^1
Division by 5 (number ends in 5)
1925/5 =385 -------> 1 division by 5
385/5=77 ----------> 2 divisions by 5 and no more (quotient does not end in 0 or 5)
3rd factor is 5^2
Division by 7
77/7=11 --------> 1 division by 7, and no more
4th factor is 7^1=7
Division by 11
11/11=1
5th factor is 11^1=11
Assembling the factors 2^2, 3^1, 5^2, 7, 11
Prime factorization of 23100 is
23100=(2^2)(3)(5^2)(7)11
Dividing a number by Avogadro's number. It is not working. Do I need to change some setting?
Nothing of the sort. Just locate the EE key. You access it by pressing [2nd][x^-1]. It is the one below the [sin] function key.
To enter Avogadro's number
Key in
6.02 [2nd][x^-1] 23 [=/Enter]
If you divide by that number just enclose it between parentheses to ensure correct calculation.
You can also enter it as described 4 lines above, press the = key. The number will be displayed. To divide by it, press the [x^-1] key and its reciprocal will be displayed ready to be multiplied.
This is so easy but I've forgotten. I have an old manual Casio caluculator. I just want to divide a series of numbers by 4. I can't seem to figure out how to do it. Any ideas? Thanks, Julia
If your calculator has the capabilities to do constant calculations here is how you perform calculations with a constant.
  1. Enter the constant (4)
  2. Press the operation key (/) once.
  3. Press the operation key (/) a second time.
  4. Your calculator may show a k in its display (LCD)
  5. To divide a number by 4, enter the number and press =
  6. To divide another number by the constant (4) , Enter the number and press =
  7. Keep entering the dividends and pressing =
I hope it works for you.
4helpful
285 divided by 13
That is the answer in fraction representation. If you want to convert it to decimals use the [S<->D] key. Every time you press that key the displyed result changes to the other form.
Hope it helps.
1helpful
2001 Mitsubishi Montero Sport fuse for lighters
Check the rest of the fuses. Most of the time, the audio cuircut is divided or supported by two fueses,. Not nessesaraly marked as radio, so look all of them., If avalible use a test light , W/ key in the on Postison, .
Accessing divide symbol on T40
To access the euro symbol on the 4 key, press the "Alt Gr" key + the Number "4" key together at the same time.
Can't reset
You reset it by pressing simultaneously and holding the two yellow keys on both side of the navigation keys.
Hope it helps.
old marine
old marine
ZJ Limited
ZJ Limited
