How do I check to see if my guitar is genuine through the serial number
SOURCE: which string used for epiphone gibson lea paul special II guitar
This is really a personal choice as long as the strings are made for an electric guitar there are hundreds of different kinds, it mostly has to do with the thickness of the strings and how the thinner the string the easier it is to manulipulate, you should go to a good music store and tell them what type of music you play and they will give you some choices.
SOURCE: Gibson Les Paul wont stay in tune
clean out the slots with the stings use gibson vintage nickle wound 10s smooth notches on bridge dry graphite on nut slots lite oil on metal bridge 3 wraps on tuning posts hold 1st fret pull strings up to stretch and retune,do this a few times always set guitar on a stand to acclimate to, the temp at the gig ,you must spend the time to stretch out the strings. Jim 30 yr guitarist
SOURCE: Digitech Vocalist Live 4 blead through
I'm having a similar problem with my Sterling audio ST-55 mic and a acoustic guitar. I regenerates the signal and sounds like it's under water. I turned down the mic input knob on the back of the unit until I got a clean sound. The only down downside to this is you have to practically eat the mic.
As for solution #1... Another mic choice will do the trick.
But the other technique with putting a wall between your guitar and mic doesn't sound like it would work if you are sitting in front of your digital recorder with a mic in front of you and a guitar in you lap.
SOURCE: Yamaha FG110's year (acoustic guitar) and BB450's year (bass)
According to yamaha's site, that's an invalid serial number??!!??
I would guess that might be the date code.
Other sites report 5, 6 and 8 "digit only" serial numbers.
Nothing for 7 numbers.
If i had to guess, the earliest...1971
Hope this helps.
