Question about Magic Chef MCWC30MCG Compact Wine Cooler
I have MCBC58DST and can hear the compressor runing but the frig is not getting colder then 65 degrees
The freezer is running about 26 degrees but the refrigerator is not cooling we can hear a fan running but cannot tell if it is in the frig or freezer. The temp in the frig is about 68.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Maytag Refrigerators
I have a hotpoint side by side model csx20ba xawh. the freezer will not get colder than 20 degrees and the refrigerator will not get colder than 48 degrees. what do you think the problem is.
make sure everything is clean behind and underneath fridge, also make sure fan is blowing across condesor coils and all covers in back are in place
Oct 21, 2010 | Hotpoint Refrigerators
Kenmore elite refrigerator no longer cooling
Try moving it out so that you can get to the back of it. You have power as the lights work. Here are a couple of things to check. There is a fan motor with a blade on the shaft. Turn the temp. control down so unit will cycle on. See if this condenser fan motor is running. If not, it has burn out. If it is running, check to see if you can hear the compressor pot running, You will be able to hear it come on when you turn the control down to colder.Please don't turn the control up and down, as this will cause the compressor to short cycle and lock out on overload. Wait about 5 Min. between moving control knob. If compressor doesn't run, it could be the start relay, or you have lost the compressor. There are many things that can go wrong, but these are just a couple you can check out yourself. Condenser fan motor you can replace yourself. I hope this gives you a place to start.
Good Luck, Sincerely, shastakaker7
ps Always unplug unit before replacing any parts.
Oct 30, 2009 | Refrigerators
When the frig is turned on the frig light blinks and the alarm light flashes no compressor runing
That's a sign of an overload on the frigerator's compressor. The cooling fan might not be working. Compressor needs to be checked by your technisian.
Jul 30, 2009 | Refrigerators
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
MATAG FRIG PTB2153GR FREEZER DOES NOT GET COLDER THAN 38 DEGREES F
Try turning the defrost timer clockwise until you hear it click. If defrost element and defrost thermostat are working properly, the refrigerator should begin to defrost. The timer is located inside the fresh food compartment behind plastic controls cover and also near the thermistat control.beb686d.jpg .I will be around if you need, just let me know,Sea Breeze
Mar 23, 2009 | Maytag Refrigerators
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
Refrigerator not cooling down below 60 degrees f.
hi!!! make sure your inside fan is blowing and also go to back of your frig and see if the compressor and condensor fan are working if not then thats your problem..If they are working then you have a seal system problem in your frig..make sure when you look at the compressor you try to hear a cliking sound if you do then change the current relay..Good luck..
Jan 04, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Frig and freezer warm most of the time
HI thanks for your question, i think what your problem is . the compressor is over heating and cutted out. clean all the coils at the back of the fridge. if theres a fan motor at the back make sure its going check that thanks
Aug 23, 2008 | Jenn-Air JCB2388G Side by Side...
Magic Chef MCWC30MCG Compact Wine Cooler Logo
173 people viewed this question
Top Magic Chef Furniture Experts
Sheldon Dedek
Muntejaya Ginting
Muntejaya Ginting
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
