Question about JVC HR-A592U S-VHS VCR
Cannot bring up my VCR's On-Screen menu I have a JVC VHS VCR Model HR-A592U The Menu display will not appear on screen,instead I get a black screen with lines.. The Display function works when pressed I cant program anything until the screen apprears.. Can you please help..Thanks much !!
Posted by Jadaa on
  • Anonymous Mar 01, 2008
    I have the same problem
Anonymous
You'll need to unplug the unit, wait a minute and then plug it back in. This happens to me on occasion.
Posted on Jan 19, 2008
Anonymous
    New Friend:
This problem was driving me crazy too. You can unplug the unit as others have suggested, and plug it in again immediately, but really, what kind of 'fix' is this?! I usually get this menu problem after I've used the timer to record a program. After loads of tinkering I discovered that if I press the 'Timer' button before pushing the power button the next time I want to turn the VCR on after recording, the menu never messes up. Good luck!
Posted on Jul 31, 2010
  • Anonymous Oct 21, 2010
    The same thing happens with my jvc vcr. I just tried unplugging and wating 10 sec. and plugged it back in, and guess what??????????????? IT WORKED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! thanks for the info
    Hack in Madera, Pa.
Need a remote for JVC HR-A592U VCR
Try website like Remotes.com to buy the VCR original remote.This site sell all DVD/VCR,DVD, VCR,TV and all electronics original and clone compatible remotes.
Sep 01, 2011 | JVC HR-A592U S-VHS VCR
Wont show the menu on screen
unplug vcr for about 30 sec. and plug back in. this worked for me and my jvc vcr
good luck, roadstarman
Oct 05, 2010 | JVC HR-A592U S-VHS VCR
VCR not timer recording, VCR will not turn on with timer
If no menu, unplug, and let it set a few minutes. Replug and the on-screen menu should appear. Reset the set-up (date, etc). I had the same experience as one of the other posters with JVC customer service telling me the menu button on the remote was malfunctioning, and I should purchase a new remote from them.
After you input your programming, be sure to hit the Timer button on your remote. If you want to change tapes or playback, you will need to hit the Timer button again (take it off Timer) for access to your VCR. Be sure to reset it to Timer afterwards, or you will not be able to record.
Feb 17, 2009 | JVC HR-A592U S-VHS VCR
Vcr problem
Heres the instruction manual, not sure hoe to myself but if this doesnt help ill read it and try to figure it out too :D
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Jul 28, 2008 | JVC HR-A592U S-VHS VCR
Basic Set-up
Most VCRs have a simple slide switch, usually on the back of the unit. Just slide the switch towards "4"
Jan 12, 2008 | JVC HR-A592U S-VHS VCR
Menu program does not come up
Unpluggung and re-connecting worked for me too
Dec 30, 2007 | JVC HR-A592U S-VHS VCR
Programming a vcr
How can t I get the pop up screen when I apply menu. When I press menu nothing appends. I have the illico box for HD and had the videotron tech install it so I can recorded but since the menu does not work I cannot set the time or anything else on it.
Thanks
Gilles T Garceau
Dec 11, 2007 | JVC HR-A592U S-VHS VCR
Camcorder to JVC HR-A592U S-VHS VCR
you must select the input in your vhs. usually its a line input (wether 1 or 2). try to find it also using your supplied remote for the vhs. good luck!
Feb 09, 2007 | JVC HR-A592U S-VHS VCR
Can't see menu to programme VCR
Try unpluging the unit from the wall for about 5 minutes then plug back in and turn it on,this will reset the brain and go back to normal.
Oct 05, 2006 | JVC HR-A592U S-VHS VCR
No Signal
Unplug the unit for 24 hours or more, you should be fine after that. No not just turn off, UNPLUG from the wall. Then reset the time and all the stuff should come bacK fine. If it does not then buy a new VCR because to fix this one would require a new microprocessor IC, and that would cost you double on what the VCR cost.
Sep 23, 2006 | JVC HR-A592U S-VHS VCR
JVC HR-A592U S-VHS VCR Logo
576 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
