Question about Texas Instruments TI-89 Calculator
How do you open folio in ti 89 - Texas Instruments TI-89 Calculator
2 Related Answers
Anonymous
  • 35 Answers
SOURCE: Don't know how to open StudyCards on my TI-89 calculator
The StudyCards app for TI-89 (Not Titanium).
Posted on Feb 24, 2009
onomou
onomou
  • 24 Answers
SOURCE: TI-89 & Liquids :(
The screws on the back are Torx bits size T6. You can pick up that type of screwdriver at Sears (I got a set of 12 micro screwdrivers marketed toward jewelers and hobbyists from there - lifetime guarantee) or maybe a local hardware store. Unfortunately, I'm not sure that once you're inside you can do a lot to revive your calculator. Some liquids can really take their toll on electronic circuitry, and you will probably need a volt meter and some more sophisticated tools to test whether your components are still good. Your best bet is probably to contact TI and see if they will repair it for cheap. Otherwise, I've seen (and bought) some TI-89s for $50 or $60 off eBay and Craigslist.
Posted on Oct 03, 2009
1helpful
How do I graph an equation with TI 89?
Just open the Y= equation editor and enter your equation. Use X for T. Make sure the angle unit is in radians.
I get a pop-up ballon that says "USB device not recognized"
How do I fix Error: TI-89 Detected, but could not get status with the TI-89
using the TI Connect software for Windows?
The Operating System (OS) will need to be updated on the TI-89 in order for the TI Connect™ software to detect the status. Try the following procedure to install the OS from the TI-89 Boot Screen. Make sure TI Connect 1.6 is installed on the PC.
• Connect the TI Connectivity cable to the TI-89 and the computer.
• Do not start the TI Connect software.
• Download the TI-89 v2.09 OS onto the PC's desktop.
**Force TI-89 into "Boot screen" (See instructions below**
• "Press I to install..." ([ALPHA]. [ 9 ]).
• Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader.
• Follow the on-screen directions to install OS version 2.09.
The download should begin.
**Steps for Boot Screen:**
• Take one AAA battery out, press and hold down the Apps key while reinserting the battery to force device into the Boot Code screen.
• "Press I to install..." will appear.
Once the OS has completed installation, the TI Connect™ software will be able to detect the TI-89.
At first ti connect recognized devise now saying cant find my ti-89 device
At first, open TI Connect software and open TI Device Explorer. Then in the Actions menu choose option Select Device and select Port USB, Cable USB cable and Device TI 89 Titanium(all in the same line).
See captured images:
1helpful
Ti-89 titanium
Having gone over a month with no response, I assume this is no longer a problem.
How do you type notes and save them in the ti 83 calculator?
Install the Note-Folio application. You can download it from education.ti.com >Downloads>Software and App> Ti 83/84 Plus family.
9helpful
Ti 89 detected but couldn't get status
Here is what the FAQ and Knowledge Base area of the TI site has to say about the problem you are having. Hope it helps.
How do I correct the error message "TI-83 Plus or TI-89 detected, but could not get status" using the TI Connect software for Windows®?
The Operating System (OS) will need to be updated on the TI-83 Plus family or TI-89 calculator in order for the TI Connect software to detect the status. Try the following procedure to install the OS from the TI-83 Plus and TI-89 Boot Screen. Make sure TI Connect 1.6 is installed on the PC.
If using a TI-89 calculator:
• Connect the TI Connectivity cable to the TI-89 calculator and the computer.
**Force the TI-89 into the "Boot screen" (see instructions below)**
• "Press I to install..." (press the [9] key).
• Take one AAA battery out, press and hold down the [APPS] key while reinserting the battery to force device into the Boot Code screen.
Once the OS has completed installation, the TI Connect software will be able to detect the TI-89.
Installing the note folio creater has problem with microsoft net
I had this problem when I didn't have a legal of xp, or it was something like that. I'll post comment if I remember just what it was.
TI-89 titanuim
Here is the link to te TI download site.
If you do not Macromedia flashplayer use Adone FlashPlayer. You acn also open files in browser.
Hope it helps.
2helpful
TI-89 & Liquids :(
Texas Instruments TI-89 Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
