Question about Pride Mobility Products Health & Beauty
Light flashes 12 times then speed light flashes 5 times, power light 1 time, speed light 5 times, power light 1, repeat.
5 Related Answers
Anonymous
  • 85 Answers
SOURCE: It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Posted on Apr 22, 2008
Toyota Ed
  • 1861 Answers
SOURCE: 1993 Camry Check Engine Light
Therre is no DTC code "5". The DTCs start at 12. If the knock sensor (there are actually 2) was bad, you would have an acceleration issue. The knock sensor changes the timing of the spark to eliminate detonation, or "pinging". Do you have a "Ping" condition/valve rattle on acceleration?
To reset the light, open the hood, remove the 15 amp EFI fuse for 5 minutes. Replace it, and start the car and drive it until it reaches operating temperature. If the light comes back on instantly, you have a bad sensor or a bad wire.
Posted on Nov 10, 2008
Anonymous
  • 741 Answers
SOURCE: battery light flashes red 4 times
Check your users manual. Normally if it is blinking it is powering up, but may be different depending on model.
Posted on Jan 01, 2009
Anonymous
  • 90 Answers
SOURCE: Red flashing light. Light flashes red 8 times pauses & repeats
power supply board going bad
Posted on Mar 03, 2009
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: 5 red flashs on power/standby light on kdsr60xbr1 screen blank,
Thats the error for lamp driver error. Which means the Ballast is most likely defective. You can get the replacement ballast for your model at the following link which comes with installation instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/kdfe42a10-ballast-assembly/cName/sony-parts
Posted on May 23, 2009
BLINKING GREEN LIGHT AND WILL NOT POWER UP
You can check the Error code by doing the following.
On the Front panel hold down the Device and Menu Button for 5 seconds. The LED light will then start flashing the first set of flashing lights is for the "1"5 part of the code it will then pause for about a half second and start the ones place 1"5". The code will repeat 5 times before going off.
The Error Codes: 12 - Normal Operation; 21 - X-Ray Protect; 22 - Short Protect; 23 - Loss of Horizontal Deflection; 24 - Loss of Vertical Deflection.
The problem may also be in the power supply when you first plug the device in check how many times the Led blinks if it blinks for just over a minute the power supply is working fine. If the Led blinks repeatedly and does not stop the DM is not running.
This is a link to the service manual for you TV,
http://www.service-manual.eu/model.php?id=2710
Mar 02, 2011 | Mitsubishi WS-65909 65" Rear Projection...
My nissan serena air bag light flashes on and of
"If you have the airbag light, it will show steady for a few seconds (the manual says 7 secs) after you turn the key from off to on (but not start) and then start to flash. Here is how to reset it:
1. Turn the key from off to on.
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
If it does not work the first time, just repeat the steps again."
Aug 06, 2010 | 1996 Nissan 200SX
Thomson scenium LED error code 45
When i turn it on red light flashes 3 times then 1 time, this keeps on repeading, no sound, no light
Sep 30, 2009 | Televison & Video
Diagnostic codes for 1994 Chrysler Concorde
What you are reading is a 1-2 (12) and a 5-5 (55). The 5-5 is always at the end of the code string. The 1-2 (12) indicates that the battery was disconnected and the ECU (computer) has been reset.
Apr 08, 2009 | 1994 Chrysler Concorde
Nov 09, 2008 | 1993 Toyota Camry V6
Health & Beauty Logo
37 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
