Question about Mitsubishi MSH09TW Air Conditioner
What type of refrigerant should be used in a Mitsubishi ms09tw 2001 air conditioner?
Need refrigerant. What king should I use?
Robbie Daniels
  • 25 Answers
R410A
Posted on May 29, 2014
wa2yyx
    Sergeant:
    Champion:
  • 282 Answers
The answer is R410A.
Refrigerant Types in a Central Air Conditioner
There are 2 different types of air conditioning refrigerant currently used in residential cooling systems. R-22, commonly referred to a Freon and R410A, a blend considered to be more environmentally friendly, sometimes called Puron.
R410A (sometimes known as Puron), is the industry's choice to replace R-22 in central air conditioning systems. It is less reactive with the environment while having the same home cooling characteristics of R-22. R410A is not interchangeable with R-22-you choose one or the other and your air cooling equipment is designed to operate with it. When you purchase a R-410A system, a new line set is included with your central air installation as well as a new evaporator coil. Our experience with R-410A has been excellent. New cooling systems have been dependable and efficient, as well as operating quieter! R-410A is the refrigerant of the future!
Less reactive with the environment
Replaces R-22 in the year 2020
Cannot be used with R-22 systems
Quiet and dependable
Freon, R22, heat pump refrigerant
R-22 also known as Freon has been used for decades as the refrigerant in central air conditioning systems. However it has been linked to Ozone depletion and has therefore been banned from being manufactured after the year 2010. It's price will increase as the supply decreases.
Good luck,
Marty
Posted on May 28, 2014
5 Related Answers
Anonymous
  • 128 Answers
SOURCE: Replacement compressor for Mitsubishi Mr. Slim Air Conditioner
pls no overhauling repair no spare part avaliable for hermetic comp[ressor the right is to change it
Posted on May 02, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: MMy Mitsubishi Mr. Slim Air conditioner is
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Posted on Aug 20, 2010
hvac1960
R Subramaniyam Iyer
  • 2133 Answers
SOURCE: What are the overall dimensions
You can check with your model and type log on to :
www.mitsubishielectric.com.au/.../MXZ-2A52-3A54VA-Specs.pdf
Posted on Jan 03, 2011
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: I need to know the number of amps and volts for
208/230 Volts A/C 15 Amps
Posted on Jun 08, 2011
SOURCE: Mitsubishi Air Conditioner blinking Problem
Mitsubishi inverter timer flash
Posted on Jul 27, 2013
Noise from the indoor unit of Mitsubishi MS09TW
My unit is a 3 year old Mitsubishi and it started making the humming noise you described. It is quite high and I finally got up on a ladder to have a look. It is the water pump making the noise in my case. It seemed like it was pumping a little too much water out. I undid a screw and angled the pump slightly and problem solved.
hope this makes sense and helps a little.
Jan 02, 2018 | Mitsubishi MS09TW Air Conditioner
Turning the unit on flicks the fuse off
tripping from high Amps. or check up sensitivity for the switch board
Nov 08, 2013 | Mitsubishi MS09TW Air Conditioner
I have a Mitsubishi split system with 2 indoor units (MS09TW) and one outdorr (MU09TW). The evaporator coil on one of the indoor units has been diagnosed by a A/C repair company as having a pinhole leak. I...
The following link includes service manuals for your air conditioning system: http://usa.mylinkdrive.com/uploads/documents/2388/document/MS-09~17TW,TN__MU-09~17TW,TN_Service_Manual.pdfI'm sure you find the solution inside the manual.
Sep 29, 2012 | Mitsubishi MS09TW Air Conditioner
Timer light flashing and run light on
Is this a heat pump? If maybe in the defrost mode. If you have the book on it, it should tell you what is going on. If not do a Google search for a manual and read up on it.
Dec 19, 2010 | Mitsubishi MS09TW Air Conditioner
My daughter has Mitsubishi split type air conditioner, model MXZ-2A20NA. The problem is that one of the unit puts out more cold air than in called for on the remote resulting in a room temperature that...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the mitsubishi line. The manual include both troubleshooting and installation.
heatman101
Aug 24, 2010 | Mitsubishi MS09TW Air Conditioner
Mitsubishi split-type air conditioner model MSH-26SV. When the unit is switched on, the 2 green lights on the front panel light up normally but but the unit doesn't work at all and, after a few minutes,...
Hi I have Mitsubishi split unit which is 5 years old. when turn heat mode for 30 deg C on the remote condesing unit runs for about 6 minuts and stops. what would be the Technical problem ?Thanks an Apprentice.
May 23, 2010 | Mitsubishi MS09TW Air Conditioner
My room AC , gives not 100% cooling air, ita gives only 25% cold air in room, cold air is blowing only from corners of indoor unit but at middle there is no air,
Check the outdoor side of your unit. Make sure that nothing is blocking the back and also take a hose and clean out the fines of the AC unit. If problem still persists after that, then check to make sure that the internal filter is not blocked or dirty.
May 17, 2010 | Mitsubishi MS09TW Air Conditioner
My control panel keeps showing check 0 p8
http://www.mrslim.com/UploadedFiles/Resource/OB%20274%20MS-T%20Tech.pdf
Go to this web site for a copy of your manual. It's from the Mitsubishi site.
Hope this does it for you.
Nov 26, 2009 | Mitsubishi MS09TW Air Conditioner
Air conditioning unit leaks
hi there,
there no other way to repair that leaks other than you call an ac technician from service center and they will find it to you because there are special leak detector they will use to find where that leaks was and they work it using oxy acetylene welding to patched that leak,after patching they take a leak testing using high pressure equiptment to leaks test the system.so they can charge free from leaks,leaks should be stop because to protect our ozone layer.regards
Jul 05, 2009 | Mitsubishi MS09TW Air Conditioner
Mitsubishi MSH09TW Air Conditioner Logo
203 people viewed this question
Top Mitsubishi Heating & Cooling Experts
Marvin
Marvin
NOEL
NOEL
Vernon Taylor
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
