SOURCE: LG Washer WM2455H Tub Clean Problem
Yes, it's normal. It is a safety feature because of the hot water used during the tub clean cycle. It prevents the machine from opening while the tub clean cycle is in process.
SOURCE: LG washer WM2455H The start button does not work,
Unplug the washer for 5 minutes to see if the commands for the cycle will reset. Also try pressing the stop button for ten seconds.
SOURCE: Having problems with the start button on my LG
welcome to FixYa,
Could you possibly elaborate on the issue with the LG washer you have, what is the issue with start button ?
Also if you could verify the model number is indeed a WM2688H it will save possible mis-understandings.
Thank you for choosing FixYa today, I'll watch for your reply.
Regards,
Macmarkus :)
SOURCE: why does my lg front loader washer wm-1832cw
you have either a hall senser /stator/or main board/problem.... may even be a voltage issue. check your recepticle see if its good. easy first check plug to see if its been arking on the plungs
