Question about Panasonic PT-51HX41 51" Rear Projection Television
How do I reset factory settings for a panasonic projection tv?
Model PT-60LC14
5 Related Answers
ladywinn
ladywinn
  • 5138 Answers
SOURCE: How to reset defaults Panasonic HD PT-47WX53G TV/picture
First of all are you sure you were in the factory menu this step requires alot of known how!!!!!! By using your hand unit only customer controls can be reached unless you know factory menu setup. Which starts like this ,make sure antenna to cable then go to menu set sleep timer to 30 mins exit out now enter ch 124 then press v- down on tv you should now see on top CHK ,also these sets have double convergence patterens.if you were in factory set up for more information look in www.freelists.org techassist/09-2005 .let me know if you still need help.
Posted on Dec 21, 2007
Anonymous
SOURCE: Panasonic PT-47WX53G Projection TV - convergence problem, can not align completely
I don't know why that guy told you to replace your "DC" board (that is the one you mean, right?) More likely than not, it's your convergence amp integrated circuits (ICs). I had what I think was the same problem (on the same exact model TV) you described, and I looked around alot of blogs and DIY websites, and this seems to be the most prevalent root behind these convergence problems. I ordered the two chips for twelve bucks (for both), spent a few extra bucks (like $35) on some electronic tools / solder supplies, and followed procedures laid out here at http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-i.html, as well as paying strict attention to the service repair manual (which you said you already have?). The result? No more convergence problem, and I saved myself around $400 - $550 over having it done by a professional.
Seriously-- I bet this is the culprit. Just make sure if you're gonna do this that you FIRST check the six resistors (located at spots D-7011 thru D-7016) to make sure there are none burnt out / opened. It may be that one of those is fried also / instead. Since they are far easier to replace, it's good just to rule them out first.
And by the way, just FIY, when I did this I had kept the TV unplugged for about two weeks first, cuz I wanted to make sure all the capacitors were discharged and safe. Did I need that much time? Maybe not (some have said a few hours is sufficient), but I was also primarily concerned about the Flyback Transformer and its wires, which have the highest voltage (up to 30,000 volts) and can hold a charge pretty long. And I'm still here to write about it. So, check out the link, and see if you'd like to try this yourself, as well!
Posted on Jan 16, 2009
Anonymous
  • 647 Answers
SOURCE: Lamp reset on a panasonic model pt-50lc14-k
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Posted on Nov 12, 2009
Anonymous
  • 32 Answers
SOURCE: How do I reset the Panasonic PT-40LC12 projection
Usually you hold Vol - on the tv itself and press and hold down the pip or split buttom for 5 seconds until lamp reset is displayed on screen set to 0 and thats it
Posted on Jan 20, 2010
Testimonial: "Thank you so much for your help. Worked like a charm!"
Anonymous
SOURCE: projection lamp timer reset
The others are almost right. You first hold down the minus button on your "TV", then at the same time hold down 0 on your remote. Make sure if you have a universal remote to swich it to TV.
Posted on Feb 27, 2010
I have an older PT-60LC14 and it blinks 5 red in five seconds then 2 orange immediately afterwards. Any suggestions would be appreciated!! It has been shutting off lately.
Presumably you have consulted the troubleshooting guide on p83 of the operator's guide (http://service.us.panasonic.com/OPERMANPDF/PT43LC14.PDF) ?
None of the problems listed there are an exact match for your description, and some of the 'solutions' are not what you want to hear (return to a dealer or Panasonic service centre), but it might give you some ideas.
You might try contacting Panasonic directly for advice describing the symptoms: they ought to be able to at least tell you what the flashing light codes mean.
You might also try getting hold of the Service manual for your TV which might describe the problem more accurately than the operator's guide. see eg http://servicemanualrepairs.com/book/panasonic-pt-50lc14-60lc14-43lc14-service-manual-repair-guide/ (purchase option. There is more than one manual available, and they cover more than one product, but they include the 60" model) This seems to be a free download. the download link is apparently in quite small (ordinary) print. Watch out for advertising/download managers/unwanted software etc.
16.January.2016
Jan 16, 2015 | Panasonic PT-60LC14 60" Rear Projection...
Tip
Panasonic PT60LC14 Manual Download
Download Panasonic PT-60LC14 HDTV Manual
Models: PT-43LC14 / PT-50LC14 / PT-60LC14
Have you misplaced your Panasonic PT-60LC14 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Panasonic PT-60LC14 HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
on Apr 27, 2010 | Panasonic PT-60LC14 60" Rear Projection...
My tv blinks red every five seconds three times pt-60lc14
The temperature sensor has failed its either shorted or open which will cause the 3 blink error
Feb 25, 2012 | Panasonic PT-60LC14 60" Rear Projection...
Reset lamp timer panasonic tv
PT-43LC14/PT-50LC14/PT-60LC14.
1) Make sure the TV is on.
2) While pressing and holding down VOL DOWN button on the TV, press and hold down SPLIT PLAY button on the remote until a message appears on the screen that the lamp timer has been reset.
Good luck
Note: I got it from here: http://www.dlplampguide.com/tyla1000.html
Dec 13, 2010 | Panasonic PT-43LC14 43" Rear Projection...
How to replace lamp on Panasonic PT-60LC14
Here is a link to replacing the lamp and the instructions for resetting the timer.
Just search for your set on the page.
I hope that this helps you.
asnowman
http://911phone.net/Panasonic_TY-LA1000_Instruction_Manual%5B2%5D.pdf
Jun 13, 2010 | Panasonic PT-60LC14 60" Rear Projection...
How do i reser the lamp meter after i replace the
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Per numerous members, it looks like this method works quite well:
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
Sep 16, 2009 | Panasonic PT-60LC14 60" Rear Projection...
How do i reset the lamp meter after i change the lamp
Press and hold "Volume Down" button on TV front and press "Play/Split" button on TV remote control for 6 seconds, Lamp Timer Reset message will come in screen.
Aug 07, 2009 | Panasonic PT-60LC14 60" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
Demonic-2011
Demonic-2011
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
