Question about Manitowoc Ice IY-0504A 161 Cube-Style Ice Maker w/ 560-lb/24-hr Capaci
How to clear errors on maitowoc ice IY-0504 161 ?
howard thompson
    Novelist:
    Champion:
  • Manitowoc Expert
  • 373 Answers
All you have to do is unplug the unit wait a couple minutes then plug it back in errors should be cleared but when the unit starts and runs and error code comes back there is a problem with machine. if error code comes on as soon as power is applied then you have a board problem or the code dose not clear.
Posted on Oct 10, 2014
I have a Frigidaire French door refrigerator model FGHB2866PF. Had ice jam dispenser. Display error code dl SP (dl SP). Cleared jam and emptied ice maker bin.
If you wish to get some details about refrigerator repair then check the following link ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 22, 2017 | Frigidaire Refrigerators
What is error code E3
If you have a gen one (finger ice maker) it means the th3 sensor is open. You will want a trusted technician to tackle this issue.
Mar 04, 2015 | Frigidaire FGTC2349KS Gallery Series 22.6...
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
I have refrigerator kenmore bottom freeze (water, ice disspenser) screen letter say if err, could you pl help me?
Error "ER IF" stands for ice fan error. most likely ice has build up in the fan that sends cold air to make ice. Try unplugging the unit for about 5 mins and plugging it back in to see if error is cleared. if error returns you will likely need to defrost the freezer to get ice out of fan.
Oct 02, 2012 | Kenmore Refrigerators
My Manitowoc Ice machine is making ice slowly and the ice squares are sticking together. How can i adjust or fix the problem?
You're bridge thickness is set to high, lower the bridge on the sensor located when you open the front door behind the water curtain on the top. If the sensor is scaled badly replace it.
Jan 25, 2011 | Manitowoc Modular Ice Machine Series S...
App error 523
hi my phone cannot start because iy is frozen with app error 523, how can i fix it?
Feb 18, 2009 | AT&T Blackberry Curve 8300 Smartphone
I have a problem with my clc 1180 machine.. i have an error code E020 subcode 00A3... i changed the black sensor ,the developper assymbly, the dc controll board,drum..... still i have same error....can you...
ok so this is a code for the atr sensor.. you said you changed it is that the one right above the black dev that has the connector that plugs up under the control panel. if it wasnt take that one out and clean it... you can also check under serv mode copier display dens and see what iy says under window for each color they should be around 100 you may want to try to clear R-CON but then you need to put all adjs back to door specs
Dec 24, 2008 | Canon CLC 1180 Copier
Spin Cycle quit and just hums
You may have a drain error problem.  The unit will not go into spin if the water cannot be extracted properly.  Check your filter screen to make sure that it is clear.
Nov 16, 2007 | LG WM-1832C Front Load Washer
Manitowoc Ice IY-0504A 161 Cube-Style Ice Maker w/ 560-lb/24-hr Capaci Logo
132 people viewed this question
Top Manitowoc Kitchen Appliances - Others Experts
Marvin
Marvin
Dennis
john h
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
