Question about Bosch WFK 2401
Why is my Bosch Axxis model WFK 2401 showing error 01
5 Related Answers
douglas smith
  • 1462 Answers
SOURCE: Bosch Washer WFK 2401
leaks could be from anywhere. remove the top and back cover, put on a cycle and try to trace where leak is. sorry if this is not very helpful. water in filter should not smell. this may be due to using liquid detergent which causes a smell like drains if used over a period. put on a boil wash and revert to using powder
Posted on Jun 14, 2007
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
Anonymous
SOURCE: I have a Bosch washer, model number WFK 2401 that
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
Posted on Aug 06, 2009
beltronic205
Gerry Harvey
  • 1481 Answers
SOURCE: Bosch WFK 2401On/Off Switch
You need a new switch should be able to buy on its own note wiring before doing.. it just pops out i think..good luck
Posted on Sep 29, 2009
michael_t919
  • 88 Answers
SOURCE: Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Posted on Apr 20, 2010
Code 08 on bosch wfk 2401
Faulty door switch
Aug 27, 2014 | Bosch WFK 2401
The main motor is not working. Model bosch wfk 2401
Please can you describe exactly what the machine does?
Here are main possibilities
motor brushes need to be replaced -most likely
defective motor control board
loose connectors
also..
motor tach (determines if motor is moving) circuit failed (unlikely but still possible)
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 27, 2011 | Bosch WFK 2401
What does flashing error code 2 on Bosch a WFK 2800 washing machine indicate
Problem from heating. Could be element or wires from it
Oct 21, 2010 | Bosch WFK 2401
Apr 20, 2010 | Bosch WFK 2401
Sep 08, 2009 | Bosch WFK 2401
Bosch WFK2401 won't start error code 6
Open the panel at the bottom using a 2p coin by turning clockwise
Pull the rubber hose out of the holder and drain water into a container until stops
turn large plastic screw to the left for access to the pump
Clear away and debris bits of metal, plastic, etc that has stopped the pump.
Opposite of above to reassemble
Switch on and test... good luck!
Mar 23, 2009 | Bosch WFK 2401
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Beeping
Thanks for posting this solution! I'll try it with mine.
Oct 24, 2007 | Bosch WFK 2401
Washing Machines Logo
136 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
