SOURCE: fax memory
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000100/000095/faq000195_006.html?reg=us&c=mx&lang=es&prod=mfc420cn_us&Cat=11&ot=us_ot
SOURCE: Fax says "Out of Memory"
Unplug Fax machine for a minute or two. Plug back in and try again.
Hope this helps!
SOURCE: how can I delete the memory on a brother mfc-465cn
Review page 65 in your manual. Changing the "Advanced Fax Operations:"
If received faxes are left in your machine's
memory when you change the Advanced Fax
Operations, the LCD will ask you one of the
following questions:
Erase All Fax?
Yes - Press 1
No - Press 2
Print All Fax?
Yes - Press 1
No - Press 2
• If you press 1, faxes in the memory will
be erased or printed before the setting
changes. If a backup copy has already
been printed it will not be printed again.
• If you press 2, faxes in the memory will
not be erased or printed and the setting
will be unchanged.
SOURCE: our Brother MFC 9440CN laser printer memory, keeps
When Fax Storage is set to On, copies of all received faxes are stored in the memory, thus using up a portion of the memory available for other functions.
The Fax Storage
feature is utilized for Fax Forwarding, Fax Paging and Remote
Retrieval. If you do not need these features, verify that Fax Storage
is set to Off by doing the following:
If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
