Question about Janome Memory Craft 9500 Computerized Sewing Machine
Where is the presser foot and needle bar on a janome memory craft 10000
5 Related Answers
Anonymous
SOURCE: Janome, memory craft 4800, sewing machine
how to delete programmed patterns and start new lettering
Posted on Jul 11, 2008
Anonymous
SOURCE: Janome Memory Craft 7000 Sewing
My Memory Craft 7000 sometimes does the same thing, if it's very cold. Try warming it up by placing it near a heat source, a vent or a floor heater, for a few minutes. Then it works perfectly.
I've used these machines for over 20 years now, and they're my favorite!
If this doesn't solve your problem, you need to take it in for servicing.
They are work horses, but they do need their maintenance from time to time.
I hope this helps you.
Posted on Jan 18, 2009
Anonymous
SOURCE: JANOME MEMORY CRAFT 5700 INSTRUCTION BOOK
Hi, I downloaded (for free) a copy of the Envision 8006 (and 8007 supplement) manual from the Elna website 2 1/2 years ago. The Envision 8007 is the same as the Janome Memory Craft 5700. I can email you a copy of the manual.
Posted on Apr 11, 2009
Anonymous
SOURCE: I have lost the manuals to my janome memory craft
To get your FREE MANUAL follow these instructions:
Go to Janome.com
Select USA as your country
Go to "Machines"
Select "Retired"
Select "Memory Craft 10000" from the list
Click on "Specifications"
On the top right hand corner click on "Download Manual"
A PDF file containing the manual will then be downloaded into your computer.
Job done!
Posted on Mar 19, 2010
bargainbox
Hassy
  • 1388 Answers
SOURCE: I need to download a free manual for the Janome Memory Craft 8000
It is not going to happen for free.
A printed manual is $36-00 AUD HERE
Download $10-00 USD HERE
Posted on Dec 13, 2011
Error message #2
Perhaps this error list will help you resolve the problem:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwijuKaq-9fJAhUD6WMKHXLVCyYQFggjMAE&url=http%3A%2F%2Fwww.janomeservicevideos.com%2Fwordpress%2Fwp-content%2Fuploads%2F2015%2F02%2FError-Codes.pdf&usg=AFQjCNHyJmEhmZ9Avh-lSL4Y0vVHEYM1yg&cad=rja
Try lowering the pressure foot and the needle and then raise them
again and then restart the machine, and if that doesn't clear the
error message then it's time to service the machine.
Dec 12, 2015 | Janome Memory Craft Clothsetter 10000
Diplays #8 to raise foot and needle and restart but then just displays same thing
My gut instict is to say that you may have a faulty presser foot position sensor. If this goes bad, even if the presser foot is raised, the machine thinks that it is down, no matter what. There are few other issues that could cause this problem, but they are all tied to faulty electronic components. I would earnestly suggest taking your machine in to a Janome dealer or another reputable sewing machine repair shop.
Mar 21, 2015 | Janome Memory Craft 10000
Displays #8 to raise foot and needle and turn back on but just displays same message
When I have the walking foot on the needle hits on the back of the foot.Janome 4800 memory craft
Is it a Janome brand walking foot? some generic feet and other brands don't fit the older Janomes.
Feb 12, 2015 | Janome Memory Craft 10000
How do I fix the following problem with my Janome MC9000 sewing machine?
Unfortunately you are probably not going to be able to fix this.
It needs a sensor adjusted (probably), or a component replaced.
Sep 25, 2014 | Janome Memory Craft 9000 Computerized...
I am getting the message Raise the Needle Bar slowly. I can't find anything about a needle bar in the instruction book about a Needle Bar.
Just turn the hand wheel. The needle bar is the round bar that the needle is inserted into and is what makes the needle go up and down as you sew.
Mar 16, 2010 | Janome Memory Craft 10000
How to put on presser foot "p" to embroider
Not shure you can embroider on an MC4000, i think this is only a sewingmachine.
But to change presser fot:
If it a "snap on" foot, when foot lifted, press the "button" on the back of the needle bar (on the bottom) this would release the presser foot.
If is a large foot, you have to unscrew the screw on the left side of the needlebar, and change the whole foot.
Jun 21, 2007 | Janome Memory Craft 4000 Sewing Machine
Janome Memory Craft 9500 Computerized Sewing Machine Logo
114 people viewed this question
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
