Question about Refrigerators
Ice maker is not working but water dispenser is.
I had a big party and the ice bucket was emptied the following day it was still empty. I checked to make sure everything was connected properly and from what I saw it was but still NO ICE. Please help if you can.. I have the same problem. Only 1-1/2 yrs old and stopped making ice. light was on that said needed a new filter. Replaced the filter, but only the water works and not the ice. I have the ED5LHAXMO10 which says you just unscrew the old filter and screw in the new one. The water is supposed to automatically shut off and come back on when you remove or reinstall the water filter.
Posted by TXANGEL0316 on
  • juni0r Jan 06, 2008
    i have a hot point side byside refrigerator water dispenser is working properly but not the ice maker. i dont see any water flowing into the ice maker compartment
Anonymous
    Problem Solver:
  • 19 Answers
Check for right direction on the filter,check the water intake solenoid valve.water presure.check that the bin is seated properly and all interlock switches are closed and working.
Posted on Nov 05, 2007
  • Anonymous Nov 05, 2007
    check and see if the nozzels are blocked..run with apple cider in the unit until unblocked.install new filter and some sort of water softner...hope you come right.
1 Related Answer
Alastair Milne
  • 22 Answers
SOURCE: Ice maker is not working but water dispenser is.
check you havent put icemaker onto vacation mode.. also if it has infra red sensors at both sides of ice maker unit , these can go faulty.. ally
Posted on Jul 02, 2007
How do I Prevent ice dispenser from freezing up? Ice is in the ice bucket but will not disperse.
The ice stays in the cubemaker tray for a set time and then empties into the bucket. If the freezer was too warm the ice wasn't frozen enough when the cube maker emptied it and it all stuck together. Now the fridge is cold again empty the bucket, make sure there is no ice stuck in the dispenser and try again. If it is a Samsung fridge do the above and turn it off for 30 seconds and back on again. Sometimes the controller and display freezes and reads the wrong temperature.
Nov 18, 2014 | Refrigerators
Will not dispense ice
commonly what you will find on that model is the main control board on the back of the unit is the source of your issue, it begins like a computer virus where the unit will render the water in the door feature useless, next goes the ice delivery sys, then the unit does not defrost properly causing cooling issues. But before running out and getting a new control board go by this check list first: 1) make sure your ice bucket is properly seeded, 2) make sure the ice in the bottom of the bucket is not melted together if so empty good ice in seperate container and put back in freezer quickly to avoid melting then run hot water in ice bucket to melt remaining bad ice afterwards completely dry ice bucket and put good ice back in and see if it works properly, 3) make sure the auger mtr is not seized due to door being left open and humidity freezing in mtr gear.
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Apr 16, 2012 | GE Refrigerators
Kenmore Elite side by side 106.4442 603. Out of power for 24 hrs and after that the ice dispenser doesn't work properly. It makes ice and dispenses water but no ice is coming out. Could it be a frozen...
During the power outage im sure some of the ice melted and then refroze into a big block in the ice bucket did you remove the ice bucket and empty all the ice from it?
Aug 24, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
All of a sudden my ice maker is not working. The
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
vxnqer
May 13, 2010 | Hotpoint HSS25GFP Side by Side...
heatman101
bvvc
Mar 21, 2010 | Hotpoint HSS25GFP Side by Side...
My ice maker stopped working. Yesterday I emptied the ice bucket as a bunch of cubes were frozen together and it would dispense. I've turned it on and off but nothing. There is no ice in the bucket and the...
You need a new water valve on your LG fridge. This is a simpe repair and we have parts so just contact us with your beand and model number.
We look forward to working with you.
Nov 04, 2009 | LG LRFD25850 French Door Refrigerator
Ice maker
Hi, it sounds like made the inlet tube to the icemaker is frozen up. First thing to check tho is that the water valve to the icemaker is ok. If you take the water line off of the icemaker valve, you should be able to blow through it. If you cannot blew through the inlet line that leads to the icemaker tube, it is plugged with ice. You cn thaw that tube out woth a hair dryer.
If I can help further, please let me know.
Thanks
Vic
May 11, 2009 | Refrigerators
Try the following check:
First make sure that the temperature in the freezer is 5 degrees or below.
Self-Diagnostics
Unplug the fridge and then plug it back in.
If the compressor is running when you unplug it make sure that you wait 15 minutes before you plug it back in.
You will then have 60 second to open the freezer door and 2 second to view the LED output code.
Ice maker check 3 pulses pause 3 pulses
Optics receiver 4 pulses pause 4 pulses.
Optics emitter and receiver 2 pulses pause 2 pulses.
All good 5 seconds on
Dec 28, 2007 | Whirlpool ED5SHAXM Side by Side...
Jul 02, 2007 | Whirlpool ED5SHAXM Side by Side...
Refrigerators Logo
472 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
