Question about Canon EF-S 17-85MM F/4-5.6 IS USM Lens
How can i fix my problem with canon lens 24-70mm ..its stuck and only turns from 35-70mm also autofocus goes fine from 3m and more to 1 m but does not move from 1m to higher distants :(
MIke
  • 685 Answers
That should be send back to Canon for repair.
Posted on Oct 21, 2014
3 Related Answers
Anonymous
  • 12 Answers
SOURCE: my canon 18-55 IS lens cant autofocus
try clean the contacts you're self by using an eraser or cleaning pencil.
did u check the Exposure Meter is working correctly?????????
Check that [email protected] reply to my mail..
Posted on Nov 05, 2009
Testimonial: "Hi Seyapathum! I tried cleaning it. and also the body. But same thing happened. the meter is still working. coincidentally, the body's curtain"
Anonymous
  • 21 Answers
SOURCE: I dropped my 70-200 2.8 canon IS lens. The lens
Best option for repair is CanonUSA repair service (presuming your are in USA). Your warranty will have their contact info, or you can get if from their web site. Though still under warranty, since it was dropped, I'd guess they would charge for the repair (but might be kind enough to give you a break on costs). Another possibility is a local Canon authorized repair shop, but what, and the extent, of damage may preclude anyone other than Canon's repair location from attempting any repair. Dropping it is a bummer, huh?!
Posted on Oct 16, 2010
Anonymous
SOURCE: canon EF 50mm 2.5 macro autofocus broken. buy new
I thought mine was broken but i cleaned off the copper tips on the bottom with a clean eraser very gently, and afterwards i put on the lens and it worked. I would give that a try if you have not already
Posted on Jan 11, 2011
Canon lens 18-35 tries and tries to focus
If the focus works OK in manual focus and you are getting problems with auto focus you may have a broken or worn ribbon in the lens.
Manual focus ring stuck
Sand or some kind of dabre in in focus gears, Needs to be takin apart and cleaned, This is in the middle of the lens,
Canon Rebel XSi won't autofocus and makes grinding sound
There is nothing that auto-focuses except the circuit in the body - all the motors, gears etc. are in the lenses. If this is a 18-55 lens then more than likely the long shaft gear has broken teeth - a very common problem.
Autofocus Failure - stopped working
Replace the broken ribbon cable in the lens
1helpful
2answers
Autofocus has failed on the CAnon EOS 40D. I can power the camera up with lens in manual but as soon as I go to autofocus it becomes unresponsive. The viewfinder goes black. Swapped batteries and lenses....
It's not the Autofocus, there's no 'non-engineer' fix. Lens and slider have failed, it's basically broken inside and I suspect it was the original fault. It's about £160-200 outside of warranty to fix via a canon authorised repair agent such as www.camera-repair.co.uk in Colchester. Send it back, get your money back.
1helpful
New Camera
Get the Canon EF 70-300mm IS USM about $500 and EFS 17-85mm IS USM about $300. The 75-300 all of them I would not use them 4 a body cap. Camera is fine or step up to XSI.
8helpful
2answers
Canon ef 50mm 1.4 can't focus <1m
If the AF motor is still alive + spinning, this should be fixable without any replacement parts.
Following URLs might be useful:
http://www.flickr.com/groups/canon_50mm/discuss/72157603775874649/
And this one - detailed instructions how to dismantle this lens and fix the issue similar to yours.
http://www.fotomozaic.ro/artikel.php?idstory=225&s=1
Hope this helps - good luck!
Raf
2answers
Zoom ring on 18-55 mm lens is locked/stuck
Are you sure it's the zoom ring that's stuck, and not the focus ring? The focus ring doesn't move when the camera is in autofocus.
If it's indeed the zoom ring that's stuck, you can spend more money than the lens is worth in repairs, or buy a replacement (circa 35 dollars on ebay) for dreadfully cheap. Good luck.
Autofocus is stuck on Quantaray 28-200mm F3.8-5.6
NEVER open it up. You will destroy the dust seals. Have Canon repair it.
Canon EF-S 17-85MM F/4-5.6 IS USM Lens Logo
Top Canon Cameras Experts
old marine
old marine
Ekse
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
