Question about Polaroid FLM-3232 Television
Polaroid FLM 3732 doesn't read a signal when all other tv do.
Frank McDONOUGH
    New Friend:
  • 24 Answers
You could do 2 things:You can buy the big chrome control box for about $160 or you could take the control box apart and replace the main board for alot less money.Usually there are 2 boards inside the power and inverter are on the same board then the main board with all the RCA jackson it is the one to replace.
Posted on May 27, 2014
5 Related Answers
Anonymous
SOURCE: POLAROID FLM-2011 REMOTE CODES
My cox remote guide lists for the Polaroid TVs the following codes:
LCD TVs: 1276 and 1316
TVs: 0765, 0865, 1276, 1314, 1316, 1326, 1327, 1328, 1991, and 1992
I hope one of them works.
Posted on Oct 12, 2008
Anonymous
  • 1139 Answers
SOURCE: Buzzing sound
Hello, This is a problem with the switching transformer or the ballast used to fire the backlight. You will have to replace the ballast and or the switching transformer soon. In order to replace these items, I would suggest taking it to a qualified TV technician for servicing. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 11, 2009
Anonymous
SOURCE: I have a Polaroid 37 inch Tv model FLM-3732.
It turned out great!!!! replaced the capacators within 30 min and $3.50 in parts!!!!!!!!!
Anonymous
  • 3 Answers
SOURCE: TV won't turn on.
The YouTube video was correct solution for me, i went to Radioshack and bought two (2) 1000uF capacitors 35 wv part#272-1032. I already had all the soldering tools, i used a desoldering wick and my suction tool, the suction tool worked better. after installing the caps, put the board back into TV and turned it on.. all is well so far. i paid $3.44 for the parts. even if you have to buy a tube of solder, solder iron (15 watt max), and de-soldering tool it's still cheaper then repair shop and got nothing to lose even if you are a novice with soldering. :) Good Luck and thanks you guys for the lead on fixing my TV issue!!!
Posted on Aug 04, 2009
Anonymous
SOURCE: If anyone is in need of Polaroid lcd tv parts contact me
usually capacitors are the problem on the TDA03211c power supply. 450v (volts) @ 10uf. change both. beside inverter filters.
Posted on Mar 31, 2010
Tip
Polaroid FLM-3732 Service Manual Download
Download Polaroid FLM-3732 LCD HDTV Service Manual
Models: FLM-2632 / FLM-2632M / FLM-2634B / FLM-3232 / FLM-3232M
Models: FLM-323B / FLM-3234B / FLM-3732 / FLM-3732M / FLM-373B
Models: FLM-3734B / FLX-374
Have you misplaced your Polaroid FLM-3732 LCD HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3732 LCD HDTV Service Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Polaroid FLM-3732 Manual Download
on May 01, 2010 | Televison & Video
Tip
Download Polaroid FLM-3732 LCD HDTV Manual
Have you misplaced your Polaroid FLM-3732 LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3732 LCD HDTV Users Guide?
Follow this link
I hope that helps.
_____________________________________________
Where can I purchase a power supply for my non functioning flm 3732 polaroid tv?
Have you checked Ebay?
http://cgi.ebay.com/MLT070AX-POLAROID-FLM-3732-POWER-SUPPLY-/120567221766?pt=LH_DefaultDomain_0
May 21, 2010 | Polaroid FLM-3732 Television
Tip
I hope that helps.
on May 01, 2010 | Polaroid FLM-3732 Television
Tip
Follow this link
I hope that helps.
High pitch screech w/no signal
is this a picture tube type of tv? big in back? If so, it could be the tube/circuit short.
If it flatpanel, it could be a bad capacitor in the DM or "Y" board or even possibly faulty power supply. Further testing will be necessary
Jul 22, 2009 | Polaroid FLM-3732 Television
Buzzing TV- Polaroid 37" FLM-3732
i fixed one by put 2 new caps in c112 and c113 1000uf 10v
Jun 13, 2009 | Polaroid FLM-3732 Television
Polaroid FLM 3732
Comment by boommer, posted on May 24, 2008 im having same problem no picture on tv blue light just flickers was unplugging it and tv would now thats not working antmore
Apr 29, 2008 | Polaroid FLM-3732 Television
Polaroid FLM-3232 Television Logo
32 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
