Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
How can i unlock my stovetop?
I CLEANED MY OVEN, THE OVENDOOR UNLOCKED BUT MY STOVETOP DID NOT.
4 Related Answers
reg501
Richard
  • 413 Answers
SOURCE: cant unlock self clean oven door
Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
Posted on May 29, 2008
Anonymous
SOURCE: cannot unlock self-cleaning oven
I ran the cleaning cycle again, and it the door opened without difficulty.
Posted on Sep 14, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore Oven door won't unlock
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 15, 2010
allbrands
Victoria Gadawski
  • 600 Answers
SOURCE: The oven door locked and
Hello, Thank You for using FixYa. I will be helping you today.Try unplugging the unit or turning power off for five minutes and see if it unlocks.The lock cycles when power is turned off and back on.
Thank You and please rate my answer if it was helpful..
Posted on Jun 17, 2011
Oven door is locked with food in it how to unlock asap
Hi , Anon !
My name is Ashlynn .
If your oven is locked , here's some ways you can unlock it :
  • 1 Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • 2 Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3 Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4 Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    But it seems you have food inside so ,
    Press cancel on the cooking cycle , and let it cool to room temperature , and then try to open your oven .
  • Feb 25, 2015 | Maytag Ovens
    Cannot unlock oven door
  • Here it is!
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    Nov 10, 2011 | Maytag Ovens
    How do i unlock a de dietrich oven?
    In order to unlock the oven you need to perform the following:
    Jun 25, 2011 | De Dietrich Ovens
    How to lock and unlock stovetop and oven door
    we need to for wich brand and model
    Jun 05, 2011 | Ovens
    My oven/stovetop isn't turning on, and it says "LOC" on the screen. Its like the stove won't ignite. What should I do?
    To lock/unlock the controls: Turn all surface burners off.
    Touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until the display shows LOC.
    To unlock the control, touch and hold the GAS/CONTROL LOCKOUT pad for 3 seconds until LOC disappears from the display.
    Feb 11, 2011 | Whirlpool Ovens
    HOW TO UNLOCK THE OVEN DOOR FOR THE DIETRICH OVEN MODEL DOP440BE1
    Thank you for contacting Fixya.com
    Aug 07, 2009 | De Dietrich Ovens
    Moisture developing between the glass on the ovendoor
    when the oven comes new ,,you must burn the coating of for about an hour..a form of food grade rust proofing..let unit bake at 400 for 55 to 65 minutes empty
    Dec 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    My Oven and broiler won't heat but stovetop burners work
    I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
    Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Ovendoor doesn't shut all the way now...
    unplug it then plug it back in... it worked for me
    Jul 23, 2008 | Whirlpool GMC305PD Electric Single Oven
    Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
    Top Kenmore Ovens Experts
    Michael Thomas
    Michael Thomas
    Marvin
    Marvin
    Are you a Kenmore Oven Expert? Answer questions, earn points and help others
