Question about Creda Ovens
I have a double electric creda oven and i have just had the house re wired. becasue the power has been off the oven is flashing on the display at 0:00 auto and i cannot switch my main oven on as when i press the manual button nothing happens?
Posted by teresa foye on
joe stuard
    New Friend:
  • 15 Answers
While holding minute minder and cook period buttons press + or - to set the time after time is set release buttons this should allow for normal operation
Posted on May 27, 2014
5 Related Answers
Robert Hirst
  • 833 Answers
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Posted on Dec 07, 2007
Anonymous
SOURCE: Wiring Diagram for AEG Build-in Electric Oven B2.6L
can i use 13amp socket for a electric oven
Posted on Oct 25, 2008
Anonymous
  • 4 Answers
SOURCE: Main oven won't turn on
I'm figuring you've probably resolved this, since you posted in November (and I've just joined the site today). However, I thought I'd post a solution just in case anyone else surfs in and finds the same problem.
We have the same sort of oven. After the power has been off, the oven won't work until you set the time on the clock. I think it's because of all the automatic timer features.
On ours, you have to press the two buttons with arrows on at the same time as turning the clock dial to change the time.
Good luck.
Posted on Jan 07, 2009
Anonymous
SOURCE: tricity bendix double oven
My oven's fan is working but no heat what so ever what shall i do
Posted on Jul 24, 2009
Anonymous
SOURCE: Automatic button on lower oven
This is how I reset my U1420NOGB/FD7907 NEFF double electric oven that I inherited also without an instruction book.
There are 4 buttons in a row and then a timer knob that moves left and right.The first button is black,second has an arrow,,third has an arrow and fourth a hand symbol on it.Hold down together, the black button and the arrow button next to it.Without releasing either,twist the timer knob clockwise(to the right)until correct time is showing.Do not release the other buttons at all ,until time is ok.If you miss correct time keep going ,dont go backwards.When time is correct,,release black and arrow buttons and auto will stop flashng ,and oven work.If auto doesn,t stop flashing at this point press the button with hand symbol (manual)on it once.
Posted on Jan 10, 2010
Hotpoint oven display not working just clock flashing
Your electric stove has power through 220, wired separately from the rest of the outlets. Go to the breaker for this, shut down total power, and see if that helps. Sometimes it does not take much to reset.
Mar 05, 2014 | Neff U1661 Double circotherm super...
Where is the thermostat located in the main oven of my Creda Europa Solar oven. Thanks
Depends which thermostat you are referring to.
Thje main oven stat is on the control panel, and is marked with the temp, the sensor being located at the top rear of the oven compartment.
The other stats are located at the top of the oven outer casing under the the top cover. you need to remove oven from housing to access these.
Oct 29, 2010 | Creda Europa E010E Electric Single Oven
Oven does not work,no display.
the display board itself would be the culprit,the part might be under warranty,if under 5 years consult manual or manufacturer for coverage....the part is probably expensive
Mar 06, 2010 | Whirlpool RBD305PD Electric Double Oven
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Display works but no lights on either oven and no fan
If the display is flashing, it sounds like the timer needs resetting
U need to refer to your instuctions on how to do this..
If it does it again once u have reset it, then I suspect that the oven element has blown..
Pls leave feedback.
Thanks.
Nov 28, 2008 | Hotpoint DY46 Style Line Stainless Steel...
Oven fan
Helt, there was a service flash on this model having to do with a wire in the wiring harness not made to specifications. Now, Im just going by the model number posted. Depending on your serial number your model could be included. What it sounds like is that your fan limit switch is gone wacky. This is located in the rear of the oven and tests would have to be done to determine if that switch is closing for some reason. There were other service flashes on this model concerning the thermal cut out mounted just below the vent causing it to open during cleaning. You might want to call for service and see if your appliance is covered under these service flashes. Catriver..post back.
Feb 10, 2007 | Whirlpool RBD245PD Electric Double Oven
Ovens Logo
155 people viewed this question
Top Creda Ovens Experts
Pcm2048
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Creda Oven Expert? Answer questions, earn points and help others
