HP DeskJet F380 All-In-One Printer Logo
Question about HP DeskJet F380 All-In-One Printer
Hp deskjet f2280 reset - HP DeskJet F380 All-In-One Printer
5 Related Answers
Anonymous
SOURCE: Carriage error Hp F2280
Same thing happened to me and I took it back to the store, where I bought it from. They replaced it with a new one and told me that it didn't have any software installed, like if you have a motherboard without bios ..
Posted on Dec 23, 2008
Anonymous
SOURCE: HP deskjet f2280 won't scan
you can try clicking MY COMPUTER then C: then PROGRAM FILES then Hp then Destination folder then bin then find the hpscnapp with a printer icon.Scan will work.Hp 2280 frequently encounters error especially if you're using VISTA. Hope i helped! Good day!
Posted on Aug 05, 2009
Anonymous
SOURCE: hp deskjet f2280 pinter windows 7 driver free
Hp deskjet f2280 pinter don't install in windows 7. now what can i do ?
Posted on Jun 15, 2010
Anonymous
SOURCE: how to change the ink cartridge in a hp deskjet
Hi you literally just pull it out and then insert the new one untill it clicks back in. I've just done mine after scratching my head! :)
hope this helps
Posted on Aug 12, 2010
Anonymous
  • 1570 Answers
SOURCE: my HP deskjet F2280 is blinking and not print.i
Hi
Please try to reset the printer.
Please try this solution.
Remove the USB cable into the printer and leave the printer on.
Remove all the cartridges.
Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
Disconnect the power cable and from the power source supply.
Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
Reconnect power cord and turn on the printer.
Return all the ink cartridges and close the door. Wait for the calibration process.
Print the test page to check if it working.
Reconnect the USB cable and try to print again.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Posted on Apr 19, 2011
1helpful
My hp deskjet f2280 printer does not photocopy. It displays an "E" error message, always.
I have got exactly the same problem. E shown. F2280 does not copy. Otherwise it prints and scan request from PC working.
I do hope, somebody reads the question, understands what is said and has a solution. Thanks in advance. AOS
I need installer for HP deskjet F2280
Hello
You can download drivers of HP F2280 from the link below by selecting the Operating System required for:- http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=3390947
Hope this helps, if so do rate the solution
2helpful
2answers
13helpful
2answers
Hp deskjet f2280 pinter windows 7 driver free
3helpful
3answers
HP DESKJET F2280 where can I get a CD to install
In order for you to install this printer to your computer without the setup CD , you need to download the software that you need , this is the link where you can download it.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=3390947&
HP DESKJET F2280 DRIVER
You can download the drivers from the following link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3390947&
First select the name of your operating system
Next, download and install the full feature driver
Printer disc is f2200 but printer is deskjet f2280
Don't Worry you have the right disc.
The printer you have is of Deskjet F2200 Series and F2280 Is on of them.
Although the printers are segrigated but the Printer driver and software are the same for the F2200 Series.
So you can install the same.
Good Luck
Ben Johnson
Marvin
Marvin
