You might try some lubricant like Vaseline ,sewing machine oil ,DW40 or even cooking oil and after you have soaked the zipper and along the track both ways use a pair of pliers or similar to grasp the zipper and move it in the direction that should open the zipper ! this might be difficult at the start so dont use excessive force in fact a push and pull method often works best ( or pull one way and then the other )because a realignment of the zippers teeth is often what is required and forcing the zipper can often tear them away from the material and a zipper replacement would then be necessary, other causes of stuck zippers are things like stray cotton or material caught up in the teeth and zipper ! If you do end up having to force the zipper maybe replace the zipper with a strong Velcro or a more robust zipper with larger teeth .
Nearly always, Nautica watches have a screw-down caseback. This is best opened using a case tool that provides at least three points for rotation of the caseback. Look up watch case back tool on amazon. Avoid the tools that have only two points.
Apparently, the needle hit a hard spot on the zipper. The needle could be bent/damaged, so try replacing with a brand new needle. If that doesn't resolve the problem, the machine has been knocked out of time. Search for sewing machine timing or take it for service.
Make sure it is properly hooked at the bottom. Get a cake of soap and rub it on all the zipper teeth. Carefully and slowly try to ease the zipper up. Also,make sure there is no material caught in it.
If you go to the web site www.nauticawatches.com and select "service center" you will be able to see all the service centers. Choose your nearest and ask them.
hello i have hour nautica ... number A29506.. i wants to change date ... please tell me how to chenge .. maybe you write in my e-mail [email protected] tthenks..
