I have a projector lamp replacement but I don't know where it is located on the tv please advise thank you marsha
SOURCE: jvc AV65WP74 PROJECTION TV
Just make sure they are stk392-110 I have the same tv and I just replaced them, I used generic chips and I have the same tv, also check on that board for burnt resistors alot of the time they go bad, there with be burn marks or or small cracks in them
SOURCE: I am trying to locate the power supply board on
If you have never replaced the lamp then I suspect that first as fans starting up means the power supply is working ok. The lamp may look good but is failing to fire. The part number is TS-CL110UAA.
SOURCE: hey i just replaced the lamp in my jvc 61' tv and
JVC Lamp Reset
Go to Clock-Timer Set-up in users menu. Select reset lamp.
easyab
SOURCE: I just replaced the lamp
Hi
Thanks for using FixYa. If the fans are working and the lamp is fine then the issue is with the ballast going bad. Ballast is the power supply source for the lamp, when you turn the unit on checkif you hear crackling or see a spark from the ballast as you have the back off then it means ballast(which is the power supply source of the lamp) is good, if not then you’ll have to replace the ballast. You can also test the wire that runs from the ballast to the power supply and check if it reads around 300vdc...if it does then you need Ballast. If it’s good then it’s the DMD Board that should be replaced.Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Replace the lamp cover and front panel, if necessary. Plug your TV back into the electrical outlet and power it on.
