This product is a high capacity power bank with high performance liion cell, whose capacity up to 15600mAh. It can be regarded as a charger or a backup battery with USB which can charge all smart phones and gadges including iPhone, iPad, Samsung, camera, PSP, etc with USB charging by matched discharge output cable and plus adaptor. The way of charging is connecting portable power bank with USB and laptop. It is easy to use and solves no power problem for your device at anytime. * Light-weight, slim and NewNow Power Brand fashionable design. * Built-in Li-ion battery, Huge capacity, 15600mAh(fully charges an iPhone5 10 up to 9 times!). * Dual USB port (can charge 2 gadgets at the same time) * Three LED indicators show you the energy state of external battery,with LED flashlight. * USB output port allow you to charge devices,Security Protection Design:Short circuit protection,Over current protection. * Apply to various electronics devices, such as mobile phone Mp3 ,Mp4 , PSP , iPod, iPhone and etc. * Easily fit into your carry bag and charge your mobile device anytime and anywhere. *convenient and easy to use, Great for power outages, emergencies business trip and more. http://www.newnow.com/products/newnow-bamboo-vi-15600mah-portable-double-usb-port-external-battery.html
SOURCE: BATTERY CHARGER RADIO SHACK DELUXE 10 CELL
I would go to Radio Shack and have them explain the proper charging procedure as well as inquire about the red and green lights as not all chargers go green when fully charged-Normally red indicates a charging action and if a charger has no fully charged light, then a required charge time period is noted in the instructions. Batteries can be ruined by over charging!
SOURCE: Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
SOURCE: LED Light on or off indicator
on my charger the red lights are only to tell there is power connecting especially when you have two battery's behind each other on the bottom of my charger there is a guide as to how long you should charge each battery as to size which are aaa 7hours max
aa 24hours
c 24hours
d 24hours
9v 24hours
hope this helps glenn............
SOURCE: Charging Batteries
This could happen if the batteries have been recently used, and are "hot". Chargers use one, or a combination of, "end of charge" detectors. Either it's timed, detects a slight drop in voltage, or senses temperature. Try waiting 30 minutes to an hour after use before charging. Also, be sure the ambient temperature is within parameters. Too hot or cold (we live up north...gets cold in the garage) will affect the charger.
SOURCE: I fully charge the batteries with Duracell charger
Rechargeable batteries just don't last long in digital cameras unless it is a battery pack made specifically for the camera.
