Jensen A300HLX Car Audio Amplifier Logo
Question about Jensen A300HLX Car Audio Amplifier
How to bridge a - Jensen A300HLX Car Audio Amplifier
Crest Audio CPX 1500 help.
Read the manual!
The Bridge mode on stereo amplifiers is often misunderstood relating to actual operation and usage. In basic terms, when a 2-channel amplifier is operated in the Bridge mode, it is converted into a single-channel unit with a power rating equal to the sum of the power rating for each channel, at a load of twice that of the single- channel rating. For example, the CPX 1500 is rated at 750 watts RMS per channel into 2 ohms. The Bridge rating is 1500 watts RMS into 4 ohms (minimum load). Bridge mode operation is accomplished by placing the MODE switch in the BRIDGE position, using only the BRIDGE Speakon connector or the red binding posts for the output, and using the CHANNEL A input. All CHANNEL B input func-tions are defeated and serve no purpose now. Bridge mode operation can be used to drive sound distribution systems in very large public address applications. Another common use for the Bridge mode is in subwoofer applications where very high power levels are required to reproduce extremely low frequencies with ade- quate headroom. Such enclosures usually contain 2 or 4 loudspeakers to handle the power levels involved. For Bridge mode usage, the enclosure impedance must be 4 or 8 ohms. Never below 4 ohms.
Can i get personalized garden bridges?
Yes, you can either request a customized garden bridge from garden bridges' shops, designers, websites etc. Or you can ask someone with some skills in the woodwork field to make one for you following garden bridge instructions from the web, and your own instructions for the customizing
Jan 08, 2014 • Garden
How to config to work wireless
bridge irb
interface Dot11Radio0
no ip address
broadcast-key vlan 1 change 45
encryption vlan 1 mode ciphers tkip
ssid cisco
vlan 1
authentication open
wpa-psk ascii 0 cisco123
authentication key-management wpa
ssid ciscowep
vlan 2
authentication open
ssid ciscowpa
vlan 3
authentication open
Step 5 bridge-group number
Example:
Router(config-subif)# bridge-group 1
Assigns a bridge group to the subinterface.
Note When the bridge-group command is
enabled, the following commands are
automatically enabled, and cannot be
disabled. If you disable these commands
you may experience an interruption in
wireless device communication.
bridge-group 1
subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1
block-unknown-source
Reset bridge to different router without the disk.
Follow these steps :
•1
Reset the bridge. Accomplish this by manually disconnecting the power source from the wall or the back of the bridge. Leave it disconnected for 30 seconds to a minute so that the software contained therein can fully reset. Reconnect the bridge and wait two to three minutes until the network is back up and running again. In many cases, a simple reset can solve your network-related bridge problems.
•2
Ascertain whether there is network activity on your computers. Accomplish this by looking at the back of each computer at the network card. There should be two lights next to your Ethernet port--at least one of these lights should be completely lit without flickering. This indicates that the network card in the machine is operational and ready to receive a signal, eliminating that as a possible problem source.
•3
Move the bridge to a different location to determine whether interference is preventing the network computers from receiving a proper signal. If possible, relocate the bridge to the same room in which the computers are located and try to reset the connection again.
•4
Determine whether the bridge has failed altogether or whether the wireless signal from the bridge has failed. Accomplish this by physically connecting the computers to the wireless bridge through the use of Ethernet cables. If this restores network connectivity, you know that the only problem with the bridge is the wireless signal emission.
1helpful
Hi there, i just had telstra install a Cisco 857w router. i am trying to setup the wrieless and am having no luck, i am not very computer literate so i may need to explained in very simple...
Need to setup the wireless on your 877W or 857w. use the following sample.. obviously update the SSID and wpa-psk key.
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
no ip address
bridge-group 1
no shut
broadcast-key change 60
encryption mode ciphers tkip
ssid MYSSID
max-associations 10
authentication open
no guest-mode
wpa-psk ascii mywpapskpwd
world-mode dot11d country AU outdoor
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 2452
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip virtual-reassembly
ip tcp adjust-mss 1400
bridge-group 1
hold-queue 100 out
interface BVI1
ip address 10.0.0.3 255.255.255.0
ip nat inside
D-Link Di-604 bridge?
I had no problem finding the Di-604 on the D-Link site.
http://support.dlink.com/products/view.asp?productid=DI%2D604
On lucent amps you sometimes have to bridge two terminals together to make it work. i need to know what two need to be bridged.
I'm not sure if Lucent has a special bridging procedure, but on most if not all other amps, when you bridge you DON'T connect two terminals together. What you do is instead of using the plus and minus terminals on one channel to one speaker and the other +/- terminals to the other speaker, you will instead use the plus (+) terminal from one channel and the minus (-) terminal from the other channel to drive one speaker and the remaining + and - terminals remain unconnected. Be sure you use the + and - terminals that are marked for bridging. Please note, that when you bridge that your speaker load DOUBLES to EACH channel. In other words, what your amp saw as a 4 ohm speaker going to one channel alone, it now sees as a 2 ohm speaker on each channel when bridged. Be sure you know what you are doing before you bridge and fry your amp. In my experience, if after bridging your amp works fine for about a month and then fries then you bridged wrong and ended up with the wrong speaker load on each of the bridged channels. Be careful. Amps cost a lot to repair. Good luck.
2answers
Wiring my subs to my alpine mrv-1000
did you read your instruction manual. does it says "it could be bridged to other amp"?. you can't make a bridge to amplifier that is not bridgeable. bridging an amp is a way which it is made through transistor type ampilfier by bridging more transistor inside and more voltage is required for bridging.
I don't know if we could do to an IC type amplifier. ask an experts about bridging IC types how to bridge maybe they know how.
and if you had an successful bridging, you may have a problem through your speakers, they may hit hard but you will experience some errors through your speakers and easy to worn.
Top Jensen Car Audio & Video Experts
ZappaNut
ZappaNut
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
