SOURCE: washer does not drain completely.
I'm not sure if this is the same model as our but I will let you know ours did not drain all the way and kept stopping, not completing the cycle. We found that if you take the bottom of the front of the washer panel off thre is a circular looking thing, it happens to be a trap for waste, sort of like the dryers lint catcher. Make sure you put something under it befor you loosen the cap water will come out. When we took the cap off, it was filled with gunk and we cleaned it out and the problem was solved!!!! Amazing because we tried everything , called everyone and not one person even mentioned we had a trap in the washer... It should be right in the center when you take the front lower panel off.. Good luck and let us know if it works for you..
Sincerely,
[email protected]
SOURCE: my kenmore elite HE3 front oading washer says 02F
"F02" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
SOURCE: Kenmore Elite HE3 F02 error
If you checked the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, first and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage this small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
SOURCE: Kenmore He3 washer manual required
See the following Sears site for on line (PDF) manuals
http://www.managemylife.com/mmh/owner_manuals/search?query=110.45872400
SOURCE: Kenmore Elite HE3 front loading washer, model
Your water inlet valve is leaking it needs to be replaced.You need to remove the top to access it.There are screws along the back edge holding it on.
The F02 error code is for a long drain. (See image below).
Without a model number I am only able to provide you with generic instructions. I have included a set of illustrated instructions you will need to check drain pump filter. (See images below). Once the bottom panel is removed the drain pump filter cover looks like a gas cap. Remove that and then remove any foreign objects. If the drain pump is clear it probably needs to be replaced.
