Question about Hayward H Series Induced Draft Abg 100,000 Heater
H100ID fan was stuck. Manually turned fan until it worked loose and sprayed silicone lubricant dielectric lubricant on spindle. Once free turning, it fired right up. We didn't use it all last summer so it probably just got frozen from bugs and such. If it doesn't turn, entire system wont fire.
Posted on Aug 23, 2019
SOURCE: Hayward Spa Heater H100ID blower will not stay on.
I had a similar problem and it turned out to be the solder connections on the control module. The connector that is soldered to this board (comes from the gas valve) needed to be re-soldered.
Posted on Jun 14, 2009
SOURCE: Fan will not turn on. the heater is a hayward
most likely a faulty ignitor
Posted on Jun 21, 2009
SOURCE: hayward h100ID ignitor not starting
There are many different things it could be with the fan comming on that means the heater is trying to fire. Make sure gas supply is on first of all. Depending on the gas line run you may have to try several times of turning on and off the heater to reprome the line. If no luck with that the next step is the igniter follow the small tube comming off the gas valve and folliw it to the burner tray try poking a small peice of wire through it from a wire brush it probally is plugged. Heater should fire after that.
Posted on Jun 26, 2009
There are several things that can cause this symptom. If you have a volt/ohm meter and call the Hayward technical support at 908-355-7995
they might be able to help you figure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 24, 2011 | Hayward H Series Induced Draft Abg 100,000...
May 19, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Aug 09, 2009 | Hayward 100kbtu Pool Or Spa Propane Gas...
Jun 25, 2009 | Hayward H Series Induced Draft Abg 100,000...
Jun 15, 2009 | Hayward H Series Induced Draft Abg 100,000...
Jun 07, 2009 | Hayward H Series Induced Draft Abg 100,000...
Jun 06, 2009 | Hayward 100,000 Btu Heater For Ag Pool And...
May 30, 2009 | Hayward H Series Induced Draft Abg 100,000...
Aug 01, 2013 | Hayward H Series Induced Draft Abg 100,000...
631 people viewed this question
