Bose Wave Radio Logo
A
Anonymous Posted on May 26, 2014
How can I record music FROM my bose wave radio TO my iphone 5 or mac book lap top computer?
I would like to tape music FROM my bose Radio TO my iphone 5 or my mac book. How can I do this?!
5 Related Answers
Anonymous
  • 67 Answers
  • Posted on Jan 18, 2008
SOURCE: Bose Wave Radio/CD Model AWRC1P
Yes There is a pigtail fuse in unit. It solders to main board. In order to replace you have to pull main p.c.b to get access to bottom of board.
jjcicala
  • 6 Answers
  • Posted on Apr 06, 2008
SOURCE: Bose Wave radio humming noise
Actually the problem was caused by a bad 470uf cap, that was used to filter the powersupply for all the analog amps. Replaced the cap the unit works like new.
wpcj-1
  • Posted on May 06, 2008
SOURCE: replace fuse Bose Wave Radio
For the AWR1-1W turn it over and there are 4 screws that you must remove. When your looking at the circuit board the fuse is just below the power supply and back of radio. If the radio makes a ‘POP’ sound when you unplug it may not be the fuse as power is getting past the fuse. I have the same trouble with mine. I called BOSE Tech and he said if it makes that ‘POP’ sound after unplugging it is not fuse or power supply. They will not even allow me to send it in for repairs as the radio is over 15 years old and considered unserviceable.
Maybe someone else can give us a quick fix.
Anonymous
  • 2761 Answers
  • Posted on May 19, 2009
SOURCE: My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Anonymous
  • 71 Answers
  • Posted on Jun 12, 2009
SOURCE: How can I get the Bose Wave radio to work in Europe??
Yes. The tuner spacing option should do this. If it's a Wave Music System or a Wave Radio II, go into the 'setup menu' and look for 'tuner spacing'. -If it's older, you may want to call Bose for a solution.
Buttons to change time not working
Bose Support - Owner Manuals
worldwide.bose.com/axa/en_au/...manuals/page.html
Bose CorporationFind Bose product informations for headphones, multimedia speakers, stereo ... IV ·Wave® SoundTouch music system IV · Acoustic Wave® music system II ... manualsfor home theatre systems and speakers ... manuals for stereo speakers ...‎Music systems - ‎Home theatre systems and ... - ‎Headphones - ‎Multimedia speakers
[PDF]The Bose® Wave® Radio Owner's Guide
products.bose.com/pdf/customer.../wrv3_guide.pdf
Bose CorporationThese CAUTION marks are located on the bottom of your Wave radio: ... the user to the presence of important operating and maintenance instructions in this.
I copied some music to a disk with 4 different formats but the bose radio wont play any of them.
The Bose Wave Radio doesn't have a CD player. The Bose Wave Radio/CD does.
It will only play standard music CD's with standard CD Audio on them.
The manual is available at Bose.com.
Is there a way that I can play music from my computer windows media center through my bose wave system?
You can obtain a cable that has a 3.5mm stereo plug on one end and two(red, white) RCA plugs on the other end and hook them into an AUX input on the wave radio
Recorded audio CD will not play
Most likely the recorded format is wrong and that is the cause.
4helpful
2answers
Non-working CD in Bose wave radio
Try replacing the battery on the bottom of the system - alot of people miss it because you have it constantly plugged into the mains, but replacing this (somehow) re-sets the system, and 9 times out of 10 solves the issue.
Bose Wave Radio with non-Bose speakers.
bose cd will not work but radio is fine
5helpful
2answers
Remote Control does not function
the conducting ink coating inside the blisters is gone. carefully open the top portion,which is stuck like an adhesive tape conducting ink black or brown is available with a hobby electronic shop put a coating on the inside of the blister let it dry stick the cover again.  p.s. bose service will tell u it is not repairable
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
