Lexmark E260dn Laser Printer Logo
A
Anonymous Posted on May 26, 2014
Why does E260dn have dark ink stripes on edges of paper?
1helpful
Hi, my lexmark e260dn "load paper" light stays on even though paper is loaded. please help
Please check if the paper guides on the paper tray are correctly positioned. For example, if you are using a letter sized paper, make sure the guides are set to 8"x11".
2answers
2answers
STARTS PRINTING AND PAPER GETS STUCK HALF WAY THROUGH. THE PRINTER IS ONLY 3MONTH OLD, HOW DO I FIX THIS.
I need to know where the paper gets stuck and does it concertina ( fold up ).
Where is the leading edge of the paper when the paper stops feeding?
The printer is printing dark along side the edges of the paper each time I print. I've changed the drum, but that didn't seem to help. What else can I do?
Print an empty word document, and if it still shows the dark lines on the edges the rollers are most likely caked with ink, and they will need to be cleaned.
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
1helpful
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
2helpful
2answers
Dark strip down center of page when coping from tray
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
2helpful
3answers
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Pictures printing with stripes of color in some programs but not all programs.
Try new injet cartidges. If your printer has separate head and ink combo, replace the jets. The high quality mode operates the piezo jets at full power and lower setting can cause jets not to open as far. On some preinters, your particalar problem can be the result of too thin paper and the economy setting being used. Use 18lb or 20lb paper and see if it still does it on normal print mode.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
