SOURCE: HOW AM I SUPPOSED TO "OIL" OR LUBRICATE A CONAIR HC115BPCS HAIR TRIMMER?
There should be 2 phillips head screws on the underside of the cutting blades.loosen them enough to where the 2 cutting blades are able to move freely then take some 3-in-1 oil and apply some in between the blades and tighten the bladesback down.Turn the cutters on for about 30 seconds and they should be good to go.Rate me FIXYA! if this helps! GOOD LUCK.
SOURCE: lost charger for conair GMT182
Call Conair, 800-326-6247. I lost charger for GMT183 and they replaced it for $5 + $.50 S&H.
SOURCE: HOW TO CHANGE BLADES ON CONAIR HCT 426 HAIR TRIMMER
digram on how to replace my blade in my hair trimmer conair hc3180v
SOURCE: conair hc318d reassembly
i have hc318d clipper it been use two time and havent use it in a year so was going to use it last nite and the small blade fell out. i try to put it back in and it want hold keep falling out
SOURCE: conair beard trimmer: took screw out and can't
After removing the screw you must place your thumb on the battery cover (just below the screw where the 5 raised lines are) and slide the cover downward. The battery in this unit is soldered in. You may have to take it to a repair center to get the battery changed. The battery is a D-Sc type 1600mAh 1.2V. Good luck finding one. I thought the battery in my trimmer was bad after it sat idle for about 8 years. Turns out a little light sewing machine oil on the cutter head made it spring back to life.
