Question about Lexmark X5150 All-In-One InkJet Printer
Documents get stuck in que on the x5150 - Lexmark X5150 All-In-One InkJet Printer
1 Related Answer
Sibananda
  • 987 Answers
SOURCE: I can't "delete" a document from the que
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side
window.
On the left side click stop the service and wait forthe process to
stop
Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue
then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler
folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them
depending apon how many print jobs you submitted. You will have to
resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
Posted on Apr 10, 2009
Document stuck in print que
Best option is to go to PC and select printer queue in Windows and cancel by selecting document.
If this does not work then turn printer off and wait a little before switching back on.
Sep 04, 2014 | Office Equipment & Supplies
Documents in printer que, but does not print
If a print job get hung up in the print que it may stop and not be able to be deleted, this will also block other print jobs from printing. Here is a link to an article that shows how to clear the print que and purge the stuck print jobs so printing can resume. I hope it helps.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Dec 10, 2012 | Sharp Mx-2310u Color Copy/print/scan
Dell V715w all-in-one print job stuck in que
If you have Windows OS, try this:
Clear Printer Spooler files and enable the Spooler service.
a. Click Start, type "services.msc" (without quotes) and press Enter.
b. Double-click "Printer Spooler" in the Services list.
c. Click Stop and click OK.
d. Click Start, type "%WINDIR%\system32\spool\printers" (without quotes) in the search box and press Enter. In the open window, and delete all files in this folder.
e. Now, go to “Services” again. Double-click "Printer Spooler".
f. On the General tab, next to Startup type, make sure that Automatic is selected.
g. If the service is not already running, under Service status, click Start, and then click OK.
Jan 27, 2018 | Dell All-in-One Multifunctional (v715w)...
Go to your search programs and files box in the start menu and type in services when you open services scroll down to Print Spoolers double click and you will see service status started hit the key that says stop after it stops hit OK to close it and reopen Print Spoolers and click open tab and then hit OK to close then close services box and you should be able to print again.
Good Luck
Aug 16, 2012 | Dell All-in-One Multifunctional (v715w)...
Me regalaron una impresora lexmarkx5150 pero no tengo el disco de intalacion
Usted puede descargar el controlador Lexmark X5150, visite el sitio web de Lexmark en http://bit.ly/f3zsdZ. Seleccione el sistema operativo, descargue y ejecute el archivo, y siga las instrucciones que aparecen en la pantalla del ordenador.
Nota: Esto se traduce con translate.google.com.
May 05, 2011 | Lexmark X5150 All-In-One InkJet Printer
There has been a pending document in the que. I tried to delete the document but now it states deleting next to the document in the que. Can not print anything.
Open the Print Que and see if it will let you pause the print job. Then close the que and turn the printer off. Open the print que again and see if it will let you delete it. For some reason every now and again a que will hang. This process should reset the que. It will dump everything in printer memory and should release the document to delete the job. In any event pausing the job should release the printer to print other jobs.
Sep 05, 2010 | Office Equipment & Supplies
HP photosmart C5280 document stuck in print que
Delete document manually from the path mentioned below:
1) Press windows + R an then type spool
2) Go to PRINTERS folder.
3) Delete the files present in there.
If not able to delete then
1) Open command prompt.
2) type "net stop spooler" and then delete the files
3)Again type "net start spooler"
Your stuck document is now cleaned. You can start printing your document again.
Mar 30, 2009 | HP Office Equipment & Supplies
Only prints one document
I would start by reinstalling the software and updating the driver. That will norrow down the problem to being hardware if it does not fix it.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Jan 24, 2009 | Lexmark X5150 All-In-One InkJet Printer
Hardware error o504
It shows color cartridge is missing because either the cartridge is not well placed or it is not there.
When you try to run the Clean option from the Ink Cartridge menu, the following message may appear: Hardware Error 0504.
To resolve this issue:
  1. Take both cartridges out of the printer.
  2. Switch off the printer using the power button.
  3. Disconnect the power cable from the back of the Lexmark X5150.
  4. Leave the power cable disconnected for 30 seconds.
  5. Reconnect the power cable and switch the printer on again.
  6. Reinstall the cartridges. (Follow the instructions on the LCD screen or refer to the following document: How to Install the Cartridges in the Lexmark X5150)
Jan 11, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
52 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
