Question about Kyocera FS-C5030N Led Printer
DIRTY PRINTS SOME PRINTS OK SOME VERY DIRTY JUST HAD PRINTER SERVICED
donovin mclain
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert
  • 210 Answers
Check the fuser or drum with out seeing the copies its hard to tell for sure
Posted on Aug 06, 2014
Faded print on right hand side
Hi Tracy,
If faded prints happen even after replacing the toner cartridge or if your current cartridge has enough toner, it is most likely be due to dust at the laser reflecting mirrors inside the printer.
I have worked/ serviced similar Laserjet Color Printer with same issue.
Actually, faded prints are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. So, it is advised that you get the printer serviced by any printer repair/ service professional. (Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors).
Hope it would help. If you need any clarification, let me know
Good Luck!
CreativeTECH
Mar 07, 2011 | Epson Aculaser C1100 Printer
Faded print on both sides.
The scanner assembly is dirty. Remove all the toner and blow with blower or cold air dryer, in the gaps at the back of the printer. If it still printers faded then the printer must be stripped and the scanner taken out and serviced. (About 1.5 hours work by expierenced technician)
Good luck
Apr 23, 2010 | HP Color LaserJet 2600n Printer
Xerox m20i scanning problems
its probably set to a low DPI.......change your dpi to like 600 when scanning
Nov 02, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Kyocera mita fs 1010- it prints on the bottom of the page only
sounds like the rollers that feed the paper in is dirty or is completely worn... clean with rubbing alcohol and clean cloth
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Apr 12, 2009 | Kyocera Mita FS-1030D Laser Printer
Ink carriage moves quickly side to side
The is because the sensor bar is dirty or has finger prints on it, (It's like a thin flim strip that runs along side the printer head - the full length of the printer)
Clean it and remove the dirt and it should print ok. (You proberly put finger prints on it when you checked for the jam!)
DO NOT USE CHEMICALS TO CLEAN IT
Mar 21, 2009 | HP DeskJet F4180 Inkjet Color All-In-One...
Brother MFC-8820D Prints a COmpletely Black Page
You have a defective or disconnected SCANNER BLOCK
Mar 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Canon pixma ip1000
as you are telling the problem is inside your printer.please get it serviced.
Apr 05, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Printer only prints partial page
hmmm...did you get new printer drivers when you re serviced machine..
www.hp.com
sort of like changing the fluids after an engine job
check your computer warranty here 4 FREE
Feb 27, 2008 | HP LaserJet 2840 Printer
Replaced Original Black Ink Cartridge but still bad low ink prints and low ink indicator lit.
Sounds like the print head is dirty take some rubbing alcohol and qtip and clean the print head.
Dec 03, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Printing missing column
This could be several things-here is a list in order of probability... 1. transfer roller dirty, especially if inside of printer looks like it needs a cleaning. You could vacuum with toner vacuum or take it in for service. 2. scanner mirrors dirty. would need to be serviced by a technician. 3. scanner toner shield out of position-tech needed. 4. toner cartridge (even though its new) needs to be shaken horizontally-toner could be all on one side of hopper. Thanks and good luck...
May 15, 2007 | Lexmark E232 Laser Printer
Kyocera FS-C5030N Led Printer Logo
121 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Timothy Van Der...
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
