My Xbox 360 (model 1439) will not turn on. When I press the sensor the noise of the Xbox turning on happens, but the green light does not illuminate and the screen does not come on either. Please if you have a solution comment. :)
Only solution i have for you is to check your connections on the Xbox, making sure that everything is right. If that checks out and you are NOT getting the red button of doom on your Xbox, then I would use a new connector or if you are using a HDMI connection use the original connector, the one with the three wire coming out the back that connects to the TV. Sometimes dumbing things down will fix it. Also check your TV and make sure that you have the right input channel on for the Xbox. IE input 2 when it should have been input 1. Not saying anything but sometimes this is the simplest solution and the right solution. Hope this helps.
Testimonial: "The red button isn't showing up but I have already tried the A/V cord since I have an HDMI cord. My Xbox is screwed isn't it?"
Maybe not i am going to give you a link to xbox forums, they have a lot more help and many others that have run into this problem. Try this place and see if anything works. Best i can do for you. Sorry
http://forums.xbox.com/xbox_forums/xbox_... Sorry about that. Hit the wrong button by mistake
