Question about Kenmore 66469 / 66462 / 66464 Microwave Oven
Kenmore oven locked out
My oven will not work,the lcd says face could this be the oven lockout que if so how do I re set.
Posted by poke on
William Miller
  • Kenmore Master
  • 9,179 Answers
Do you have your manual? If not, you can probably find it online and find contact inrfo for Sears support at http://www.sears.com
Posted on Nov 05, 2007
When I attempt to enter anything with the keypad the display says "locked". Is there some way to unlock it.
Many microwaves have children locks. Of course they are for safety reasons. they are for tricking the little kids from playing with the big people toys.
Process A
To Turn the Control Lockout Feature On or Off:
  1. Make sure the microwave oven and timer are off.
  2. Press and hold the CANCEL keypad for 3 seconds.
  3. 2 tones will sound and "LOC" or a padlock icon will be displayed (indicating the control is LOCKED).
  4. Repeat to unlock. Again, 2 tones will sound.
Process B
  2. Press and hold the START keypad for 5 seconds.
  3. 2 tones will sound and "L" will be displayed (indicating the control is LOCKED)
Hope this helps?
Jan 12, 2016 | Microwave Ovens
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwwave is not heating,
Hello
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol (like the "Start" button in the photograph).
Oct 05, 2011 | Sanyo Microwave Microwave Oven
My oven is not heating anything although everything else seems to be working fine. Your site said i may need a multi tester, what is this and where might i find one cheap.
Oct 04, 2011 | Microwave Ovens
How do I make the fan blow from inside to outside? It is ducted to go outside but is blowing inside. I just bought this house and I need to know if there is a setting or fan direction switch?
this is easy. take it off the wall and on the top in the back there is a panel take it off and switch the direction of the diverter. so it si facing either sraigft up or facing out to the back , so it lines up with your duct work.
Sep 11, 2011 | Whirlpool MH1150XMQ Microwave Oven
Display panel has lost most of its dots. can't read it
debe ser revisada por un tecnico por que parese ser la targeta de control da?ado por incectos o por cucarachas
Oct 05, 2010 | Sharp R-1750 Microwave Oven
Locked ge spacemaker xl1800
This sounds like the "child lockout" feature is on. Does the door open, but the microwave won't work. Press the "clear/off" button for 3 seconds or so if this is what you're experiencing. If not, I apologize for wasting your time.
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Hello; my oven has been working perfectly. I tried to use the defrost. For doing that I pushed several different pads. Finally with the help of the Owner´s Manual I coudl use the defrost, but the oven is...
It sounds like what you've done is locked up something in the timer. I'd unplug the unit., wait a few minutes and plug it back in. If that doesn't do it, I'd look at whether your unit has some kind of child's lockout that you may have activated. Not that...we've got to look at more issues.
Dec 31, 2008 | Microwave Ovens
No est? funcionando
El codigo H98 indica que puede haber un magnetron defectuoso, tambien que puede haber una fuente de alimentacion defectuosa o puede ser que exista un falso contacto en el connector CN702. Han habido reportes que la fuente de voltaje ha salido con poca vida y fallan a menudo.
Si habres este aparato ten cuidado con el alto voltaje que existe en un condensador de alto voltage.
Suerte.
Jan 24, 2008 | Panasonic NN-S768BA/WA Microwave Oven
Kenmore 66469 / 66462 / 66464 Microwave Oven Logo
144 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
