Question about Basketball
I need a manual on a pro shot center court 9h244 portable hoop
Posted by Jello Frost on
Adjustable basketball hoop
push on the back board up to get it to lock. Use the catch plate to bring it down.
Jun 14, 2016 | Spalding 72351 Portable Adjustable...
Need instruction manual
http://www.instructionsmanuals.com/
Feb 14, 2016 | Spalding Basketball Spalding NBA 66349...
How do I fix a wobbly in ground basketball hoop
I would clear any loose debris, repack around pole with a dry concrete mix then add water to it make sure pole is level, brace if necessary and give 24 hours to set up.
Apr 18, 2014 | Basketball
How to fix my basketball hoop
Your either going to have buy a new one which I'm sure you want to be a plan Z. With that said, your going to have to weld it at a position that is not adjustable or is possible weld and screw 2 sides where it can move at the broken angle
May 26, 2013 | Basketball
Huffy center court replacement backboard
you can go online like to ebay or some other dearler ship and search huffy center couter or (backboard) and there you go. Also its cheap
Mar 16, 2013 | Basketball
How to setup a rawling softee hoop set
Unfortunately, I couldn't find a manual or instruction guide online. Here is the contact page of the Rawlings website. They should be able to help you assemble it.
Feb 24, 2013 | Rawlings Michigan Wolverines Slam Dunk...
I need a instructions on a lifetime portable basketball goal that i can praint out
Here is a link to the manual you are looking for. I found it on the manufacturer's official site.
Jan 29, 2013 | Project Runway Lifetime 48" Portable...
How to install above the rim basketball hoop system
I believe this is the product you are referring to. The link is to the item on Sears' website. You should be able to find a manual there.
Jan 28, 2013 | Basketball
Basketball Logo
221 people viewed this question
Top Basketball Experts
Anon
Tom Chichester
Meli Dragon
Meli Dragon
Are you a Basketball Expert? Answer questions, earn points and help others
