HP LaserJet 1600 Printer Logo
b
bradley Posted on May 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP printer initializing.what can i do? - HP LaserJet 1600 Printer
Saleem Baig
Level 2:
  • Expert 283 Answers
  • Posted on May 27, 2014
Saleem Baig
Expert
Level 2:
Answers
283
Questions
0
Helped
62418
Points
806
Hello bradley
Can you please explain the correct problem?
If your printer is hanged with the LCD showing Initializing then you need to reset the NVRAM by holding the >+go button and turning on the printer. Make sure if you have network configuration then you might loss the settings.
Take care. and thanks for posting
Ethan Jack
Level 3:
Master:
  • HP Master 630 Answers
Ethan Jack
HP Master
Level 3:
Master:
Answers
630
Questions
0
Helped
133152
Points
1229
How to reset printer setting
Turn off the HP LaserJet 2840.
Press and hold down the "Enter" and "*" keys on the printer's control panel, and turn the printer back on.
Hold the "Enter" and "*" keys until you see the "Permanent Storage Init" message on the device control panel. Release the two keys to perform the NVRAM initialization. The NVRAM initialization takes just a few seconds, and the "Permanent Storage Init" message remains on the printer's display until the initialization is complete.
Ensure that the "Ready" message on the printer's control panel is visible. You can now connect the printer to your computer and print your documents. If the "Ready" message is not displayed and your printer is still stuck in a loop, turn off the printer and contact HP customer support (see Resources).
  • To reset an HP 2840 from your computer, open the HP Toolbox program, click "Device Settings," click "Service," click "Restore" in the Resets section and then click "OK" to confirm the action and restore the printer to its factory defaults.
1helpful
2answers
Printer does not reset
HP tech support might help you in this matter you can reach them directly on this number (877-690-9305) or just follow the link Support For Hp Printer
1helpful
I have a printer it is modle is Hp LaserJet p4015n, when i start it give me this error: (49.00FF ERROR To continue turn off then on). when I turn off then on it give me agane this error. thanks for help,...
HP 4015 NVRAM & hardrive initialization
Solution
A hard disk initialization will erase and reformat the printer's hard disk. Perform hard disk initialization only if an error code displays on the control panel indicating a disk error. Always try initializing the hard disk before replacing it.
1. Turn the printer on.
2. As the printer performs its power-on sequence, press and hold the Menu button until all three lights on the control panel are lit.
3. Press the back arrow . The message INITIALIZE DISK displays on the control panel.
4. Press OK. The printer initializes the hard disk and continues the power-on sequence.
CAUTION: Initializing NVRAM resets the serial number, the model number, the event log, the page counts, and the EIO card. Use the SERVICE menu to restore the serial number and page counts. You also need to reconfigure any computers that print to this printer to recognize the printer. Initialize NVRAM only when absolutely necessary. In most situations, use a cold reset to return printer to factory defaults but still retain the needed values in the SERVICE menu.
Before initializing NVRAM, print a configuration page and a supplies status page to gather the service menu values
1. Turn the printer on and watch the control panel display.
2. When the display shows the memory count, press and hold the down arrow until all three lights on the control panel are lit
3. Press the up arrow .
4. Press Menu . The message SKIP DISK LOAD displays on the control panel.
5. Press the up arrow until NVRAM INIT is highlighted, and then press OK. The printer initializes NVRAM and then continues its power-on sequence.
daca aceasta procedura nu reuseste, atunci va trebui sa inlocuiesti formatter-ul. daca nu exista hard disk
Good luck
HP L7650 Scanner Could Not Be Initialized in Leopard (Not Found)
If you're using Vista, this happens all too regularly with HP printers. I've had a few where I have to uninstall everything then re-install to make things work.
Two weeks later the same thing, same process.
Try downloading latest drivers from HP and see if that helps. HP don't admit there's a problem.
Don't seem to have this problem with Epson printers tho.
Had a problem with HP Photosmart C5180 All in One says cartridge cannot be used after initialization. Cannot find telephone number to ring HP in Ireland for support. This happens every time. I just had a...
Introductory cartridges come with the printer and carry special ink formulations intended for printer initialization. During initialization, inks in the introductory cartridges mix with inks in the printer to create a normal ink formulation. After initialization, introductory cartridges can be used in any compatible printer. However, if introductory cartridges that have not been through initialization are installed in a printer that has already been initialized, the printer cannot print
If the issue persists, perform these steps
try the cleaning steps advised in this link...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00709715&cc=us&lc=en&dlc=en&product=1153481
Remvoe all Cartridges, disconnect the printer from the computer and connect it to the direct wall outlet and Reset your Printer to initial factory default settings:-
* Remove the power cord from the back of the product.
* Press and hold down the OK and Help buttons at the same time.
* While still holding the buttons down, plug the power cord into the back of the product.
If the issue persists, perform these steps.
1. With machine powered on, unplug power cord from back of printer and wait for 30 seconds.
2. While holding down the "ok" and "?" buttons, plug the power cord back into the printer.
3. Let the Printer power up again and give it time to go through all of its process.
2helpful
HP 4600 Color Printer stays in "Initialize" Mode
If you are using a jetdirect network card it could be the cause of your problem. Pull the network card and restart the machine. Seen it a couple of times
Display reads "card slot not initialized"
2 As the printer performs its power-on sequence, press and hold the PAUSE/RESUME (HP Color
LaserJet 4600 models) or MENU (HP Color LaserJet 4610n and 4650 models) button until all
3 Press . The message INITIALIZE DISK appears on the control-panel display.
4 Press The printer initializes the hard disk and continues its power-on sequence.
3helpful
Cannot run printer...stuck on Initializing
hi,
please go through the following link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01330821&cc=us&lc=en&dlc=en&product=390328
thanks and regards
agnel
k24674
Grand Canyon Tech
Grand Canyon Tech
