usually this happens when lens cannot read the the disc. Due to few reason
1 Your disk is scratched
2 Your DVD lens is covered with dust
3 You need to replace DVD lens Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens
either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
1. Connect your VCR to your TV. (Using Antena cable or RCA cables.)
2. From your DVD player, choose the AUDIO VIDEO OUT. Then, connect that to your VCR's LINE IN jacks.
(*)Your DVD player has 3 jacks coming out. Yellow-video, White- Audio Left and Red- Audio Right.
If you VCR does not have the RED jack. Go to a radio shack and tell on of the sales person taht you need to connect 2 RCA audio outs to 1 RCA audio in. (He/ She will give you a "2RCA Male to 1RCA Female" splitter)
3. Finally, play your DVD, put your VCR channel in TV and most important select the LINE channel in your VCR. (This channal may called as L1, Line,... etc)
You should be seeing the DVD in your TV now.
If you want to play the VCR, just put the casset and play.
Important- The VCR needs to be powered on in order to the DVD signals to go to the TV.
hello. well the only thing you can do is.!!! try to find another go video player. on line .!!! try putting a add on a site that your looking for a go video vr3840 dvd/vcr player.!!! chep.!!! you never know you might get lucky and find one . well "GOOD LUCK"
You probably need to reset your DVD/VCR/Combo. Go to www.samsung.com. Go to <Support>. In the search box, type in the model of your DVD/VCR/Combo. Or type in, >how to reset DVD/VCR/Combo<. Each model has different reset method and there are hundreds of models!
853. How To Reset Your Samsung DVD Player
STEP 1
STEP 1. DVD Reset List Samsung DVD
players have a built-in reset procedure that resets the DVD player to the
factory defaults. You can use the reset procedure to reset settings that
don’t work with your TV or to resolve issues such as unit lock up. To run the
reset procedure, you press one or more buttons on the front of the DVD player
and hold them for at least fifteen seconds. The buttons your press depend on
the model you have. Important: For the reset
procedure to work, you must press the buttons on the front of the player, not
on the remote control for the player. Below is a list
of all Samsung DVD players and the buttons to press to run the reset
procedure. DVD511 - Stop
/ Play DVD611 - Stop
/ Play DVD709 - Stop
/ Play....
Many, many other models follow but cannot be listed here because of this site's text limitations.
Your question is not clear?Are you asking a blank dvd on a home line dvd recorder/player or a blank dvd from a computer or a blank dvd in a dvd camcorder?
First hook up the VR357 to the TV with any cable ..
Then put a VCR tape into the VHS player.. get the tape to where you want to start the recording and press stop.
Then put a blank DVD in (-r or -rw is the best)
Then press VCR on the remote
Then press TO DVD on remote
you will see the word COPY come up on the DVD player and the VHS tape will start to play.
When you are done just press stop twice. and you will get a message that says "updating information to disk"
I imagine you have checked the disk for scratches top and bottom, if so you can purchase a cd/dvd lens cleaner cdrom as the laser may need realigning and cleaning.
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
