Lg 37lc7d is having trouble turning on, it starts then stops, then starts and stops then turns on after a couple of mins what is happening
Posted by Steven Pritchard on
Mike M
  • 3,324 Answers
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Posted on May 26, 2014
5 Related Answers
Anonymous
SOURCE: LCD LG 37LC7D
I noticed that the power cord was loose on the back of the unit. I removed it, and plugged it as snug as it would fit. It seems ok now.
Posted on Nov 20, 2007
Anonymous
  • 44 Answers
SOURCE: My LG-37" Flat-Panel LCD HDTV-37LC7D turns on automatically
The main board needs to be replaced.
Posted on Jul 03, 2008
Anonymous
  • 30 Answers
SOURCE: I have an LG 37LC7D. Never had a problem until
You have a component breaking down electrically, a dry joint on a circuit board or it needs a good cleaning of all the electrical parts. To fix the circuit board or components, you will have to take it to a TV repair store. But first, try cleaning it. Disconnect the electrical supply and take off the rear cover. Using a fiber dust remover or a vacuum cleaner, remove any build up of dust and hair from anywhere inside the TV, paying particular attention to the cooling fan intake and ducting. Be careful not to damage any fragile components .
Good luck.
Posted on Jun 22, 2009
Anonymous
  • 934 Answers
SOURCE: LG 37LC7D
Howard,
Do not keep forcing this unit on - - This particular unit has a VERY commonly known problem and there are at least five tech bulletins from LG explaining this and other symptoms for the failure. In a nutshell there are coils that have to be removed and replaced with a jumper wire. This is not a repair you want to tackle so please get some experienced help for this one. A good technician will look-up the bulletins and educate themselves on the manner of the repair.
Almost all of the symptoms that can happen are intermittent and can be extremely difficult to verify. For this reason make sure to discuss with the technician that he replace all of the coils listed in the bulletin not just the ones causing your particular problem. Here's a list of symptoms that these defective coils cause, taken right from the bulletin:
1. Channels Or Menu Functions Scroll On Their Own
2. Remote Does Not Function
3. Tv Randomly Powers On And Off On Its Own
4. Dead
5. No Backlight
Hope this helps!
William Rayburn, CET
Premium Technologies
Posted on Aug 03, 2009
Anonymous
  • 73 Answers
SOURCE: i have a lg 37lc7d will shut its self off
When it shuts off does the power light stay on like the unit is still on?If yes,try shining a bright flashlight at the screen and see if you can see any video.If you can your power and main boards are ok.you would then probably need an inverter board or panel.If it is shutting completely off you need a main total assembly since you have already replaced the power supply.The main total assembly is avery common issue on lg lcd tv's.
Posted on Oct 15, 2009
HAVE TO TURN ON AND ON BEFOR PICTURE COMES ON ABOUT 4OR 5 TIME
I have to keep hitting the tv button on my cable remote and my tv finally comes on after about 5 mins.
Tv take a long time for a picture to appear once the power is turned on. is it a problem with the set?
no some of the new> tv < they have 15 to 10 min. window power saver on them they built them like that so just incase of an elec. storm.
I have a lg 37lc7d will shut its self off
1helpful
I have an LG 37LC7D. Never had a problem until yesterday. I turned on the tv and after about 10-15 minutes, it started to flicker, slowly at first, then it got faster and louder and shut itself off. I was...
Good luck.
2helpful
3answers
LG 37LF65 LCD TV BLINKS 3 GREEN THEN 1 RED THEN TURNS OFF.
Here's a link to the service manual for a slightly larger LG LCD TV. Perhaps it may be of some help? The troubleshooting section appears to be the same for many models of LG TVs...
http://www.observations.biz/MANUALS/LG_LCDTV/42LF66.pdf
6helpful
2answers
LG 37LC7D remote doesn't work
 I heard that Best Buy is still selling these models despite this known problem- I am trying to have mione fixed but was told the replacement part is on back order until DECEMBER!
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
Ekse
