Question about Connex 4600 Base CB Radio
Will a connex 4600 turbo cb radio operate cool enough in a dash enclosure?
Connex 4600 turbo cb
  • James Walker
    James Walker Mar 11, 2015
    dont enclose keep it open this radio has a 2290 pill like a small amplifier built into the radio it will overheat and blow this pill if you enclose it. the radio is not a radio you want tp keep keyed up talking for a long time it will overheat blowing the pill. best thing to do is have a small 1 inch fan installed inside the radio blowing on this pill 2sc2290. this will substationally preserve the life of the final.
Lynzee Newhart
I have CX-4600-T too. Mine gets way hot as well, I had a mod kit installed n it swings 215W peak power now. But the excessive heat is annoying, I think mine does have a fan in it though cause I know I felt air coming out the back before.
Will a connex 4600 turbo cb radio operate cool eno - 12_19_2018_5_04_40_am.jpg
Posted on Dec 19, 2018
Laron
    Novelist:
  • 146 Answers
I would say yes it has a large heatsink. The variable might be the tuning. But if it's amp is not being pushed any harder than factory you will be fine. Nice radio I prefer them over the 4400turbo and the 3600hp it has the board like a 4300 not the 3300s like the fore mentioned.
Posted on Jun 16, 2014
5 Related Answers
bunnydawg
Roberta Smith
  • 5158 Answers
SOURCE: owners manual for connex 4600 turbo
to cut down on noise i would hook it directly to the battery. make sure there is a fuse in the power cord first.
Robert
Please rate this solution thanks
Posted on Feb 23, 2009
Anonymous
SOURCE: Connex 4600 Turbo
i have the same radio turn talk back off and there is enough power ull have talk back through you trucks radio speakers and it needs to be hooked up to the battery with at least 12ga wire
Posted on Mar 28, 2009
gtmnow
  • 13 Answers
SOURCE: connex 4600 turbo the talk back
THE TALK BACK VOLUME IS CONTROLLED BY THE MIC GAIN, TRY ADJUSTING YOUR TALK BACK VOLUME ABOUT TURNING THE MIC GAIN FROM 12 OCLOCK TO 6 OCLOCK, DO NOT WORRY YOU WILL NOT LOSE ANY OUT BOUND POWER UNLESS YOU TURN THE MIC GAIN BELOW 11 OCLOCK
Posted on Apr 01, 2009
Mister 44
Jim Verge
  • 35 Answers
SOURCE: connex 4600 turbo radio stays keyed up even with
Bad RX/TX Transistor? I don't have a diagram for the 4600. Sorry!
Posted on Apr 03, 2010
JOHN BABA
  • 1274 Answers
SOURCE: Knob setting of front of radio (Connex 3300)
The best way to set it is to get you a radio check, go to channel 19 and ask someone about three to five miles away to give you a radio check, start with your modulation all the way open and go from there.....hope this was helpful...
Posted on Apr 20, 2010
How many feet of coax cable do i need for a cx 4600 turbo connex cb using a 102inch whip antenna ?
18 ft. you shouldn't have to worry because a 102 is carring a good match anyway.Make sure you use the good stuff and its not the skinny coax.
Jul 05, 2014 | Connex Radio Communications
Looking for a manual for my Connex 4600 Turbo
have you tried CB Tricks .com they should have what you're looking for if you take your time to find it there.
May 11, 2010 | Connex 4600 Base CB Radio
Connex 4600 turbo radio stays keyed up even with mic disconected
Mar 28, 2010 | Connex 4600 Base CB Radio
Connex 4600 turbo the talk back
Mar 29, 2009 | Connex 4600 Base CB Radio
Owners manual for connex 4600 turbo
Robert
Feb 23, 2009 | Connex 4600 Base CB Radio
Frequencies
i have a 4600 connex and if i turn the mic gain all the way up i get alot of modulation.can someone tell me how to fix that?
Feb 01, 2008 | Connex 4600 Base CB Radio
Radio Communications Logo
325 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
