this helped me with my scanmaker 3830 on windows 7 and windows 8 64bit too You can download: ScanWizard 5 version 6.63
Here: ftp://microtek:[email protected]/microtek/pcfiles/drv_sw5_v6_63_ad.exe
Extract to folder on desktop.
1. Plug in your Scanner
2. Go to Control Panel (Windows 7,8 - 64 and 32 bit)
3. Go to Device Manager
4. Go to Imaging devices (or Other devices)
5. Find what windows have installed Right Click
6. Update Driver Software..
7. Click - Browse my computer for driver software
8. Click - Let me pick from a list of device drivers on my computer
9. Click - Have Disk
10. Browse to your desktop or position where you extracted 6.63, point
to "....drv_sw5_v6_63_ad\Disk1\Vista\AMD64\..." Pick any of INF files I
picked first
11. You will see 4800 Scanner and USB 2.0 Scanner, I picked first 4800
then USB 2.0 and both works., install the scan wizard,
restart the computer
3840 is an old scanner and the latest driver for it in microtek website is for xp. but you can try using the win7 64-bit driver of ArtixScan DI 1210 which you can download here:
http://support.microtek.com/downloads/drv_specific.phtml?slct_os=22&prod=127&bymdlnme=1
after downloading, DON'T INSTALL it. put it in a folder, then using your WINRAR, extract it (right-click then click Extract Here). Then MANUALLY UPDATE your driver by browsing to your folder when windows detect your printer or click add printer in Devices and Printers in Control Panel.
You can download: ScanWizard 5 version 6.63 Here: ftp://microtek:[email protected]/microtek/pcfiles/drv_sw5_v6_63_ad.exe Extract to folder on desktop. 1. Plug in your Scanner 2. Go to Control Panel (Windows 7 - 64 and 32 bit) 3. Go to Device Manager 4. Go to Imaging devices (or Other devices) 5. Find what windows have installed Right Click 6. Update Driver Software.. 7. Click - Browse my computer for driver software 8. Click - Let me pick from a list of device drivers on my computer 9. Click - Have Disk 10. Browse to your desktop or position where you extracted 6.63, point to "....drv_sw5_v6_63_ad\Disk1\Vista\AMD64\..." Pick any of INF files I picked first 11. You will see 4800 Scanner and USB 2.0 Scanner, I picked first 4800 then USB 2.0 and both works. I managed before to do it with simple install but well, it works .. ;)
On the back of the Epson Perfection 1660 Photo there is a lever that shows a lock and a unlock by where you plug in the wire to the computer. It must be in the unlocked position otherwise it will make that loud clicking noise and not work. Hope this helps.
Download driver from the Microtek website
extract the files to your drive
locate the setup.exe file where you extracted the files
after the driver is installed reboot the pc
Now for the fun part...
Once PC is fully rebooted plug in Scanner ScanMaker s400 Windows looks for drivers in “windows update” and the “preconfigured driver folder” Windows cannot find a driver. Close “Driver Software Installation” window Open Device Manager Device manager shows yellow bang next to “USB scanner” under “Other Devices” Right click on usb scanner click “update driver software”, Click on “Browse my computer for driver software” Click on “let me pick from list of device drivers on my computer” Click on “Imaging Devices” Click Next Under Manufacture there is no Microtek Click on “Have Disk” Click on Browse Locate ScanWizard 5 V6.63 folder Locate Disk 1 Locate Vista Locate X86 There is a list of INF files Choose first inf file, “Mii_x86_004.inf” Click Open Click OK Now under Manufacture two entries are listed, Microtek and Microtek Driver Team, On the other side there is a list devices s400 is not listed There is an entry for 4800 Scanner Select it and click next An “update Driver Warning” opens select yes Window now shows successful driver update. And the scanner is listed as 4800 scanner Click close Close device manager Open Scan wizard program Scanner works fine. The scanner will not work nativly with windows scanning.
This works for Windows 7 I think it works for vista too:
that's the specific driver. download and install that. if you find that vista programs can now 'see' the scanner, but still don't 'know what the scanner is', then you can uninstall the driver again, and then go back to the exe. file and right click on it. Then click Properties. There is a chance that you will see a Compatibility tab. If you do, click that and choose XP compatibility mode from the list, press Apply, then ok. Then install it and reboot again. If it still doesn't work, then either there is no Vista compatibility for your scanner, ie it's too old to use with anything later than xp, or you need to clean the pc and the registry up with something like ncleaner, which is free and a really handy program, i swear by it.
If running XP SP2, then try clicking Start > right click My Computer > properties > Hardware tab > Device Manager button > expand Imaging devices > right click on your Microtek ScanMaker > uninstall > Re boot > and let XP pick up the device and let the found hardware wizard configure it.
I have seen plenty of hardware that when following the devices manufacturer's instructions for install, such problems as you're having occur and XP SP2 usually will cure it, though you may still need the device manufacturer's CD (for the driver) in your optical drive.
This link: http://support.microtek.com/downloads/bymodelname.phtml?viewtype=2&srch_in=ScanMaker+5950&frmsearch.x=10&frmsearch.y=11&frmsearch=Search&frm_rqst=2&axn=1 will allow you to select between the 5950 and 5950 Pro then on the next page you will be able to download the latest XP driver for your Scanmaker among drivers for other Operating Systems also.
A Scanner this old is not likely to work with a computer that is current.
You did not say if you have the driver disk to try.
If you have and have loaded the MiraScan software,right click on the program icon and click on properties then campatability and set to run as W98 and see what happens
You will not find driver for this one now.
I assume you are running XP or 2000
This scanner designed to run with W95/98 is not compatible with modern NTFS systems.
