Good Morning Friend,
I understand that water is not coming into your Frigidaire dishwasher, model# PLD2855RFC. There are a couple of things that I would check.
First, check to make sure the water supply is fully turned on.
Secondly, check to make sure the overfill protector moves up and down. The overfill protector keeps your dishwasher from overfilling and is located in the left front corner of the tub. The overfill protector should move up and down freely about one inch. If it does not move, lift and clean underneath. Clean this occasionally with household cleaner containing vinegar or bleach to dissolve any buildup.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
SOURCE: How can I properly drain
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Hello shellytake5 - Often when there is standing water in the bottom of the dishwasher, it is because more than likely the control or drain pump assembly is faulty and possibly need replacing. However, if the unit is making a grinding noise then it is recommended for the drain motor to be diagnosed. If this problem persists, you can locate a certified technician directly through the manufacturer website or in your local directory to determine what may be causing the issue at hand.
